坐等 PCB 板
发现PCB错误了 液晶接口 20和21脚 和原理图 反了 和 买的 LCD模块也 反了 纠结了一下无 总算发现了
红圈 处两个焊盘对调
FMSC 配置 程序
void fsmc_init(void)
/* FSMC GPIO configure */
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOF
| RCC_APB2Periph_GPIOG, ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
FSMC_D0 ~ FSMC_D3
PD14 FSMC_D0 PD15 FSMC_D1 PD0 FSMC_D2 PD1 FSMC_D3
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOD,&GPIO_InitStructure);
FSMC_D4 ~ FSMC_D12
PE7 ~ PE15 FSMC_D4 ~ FSMC_D12
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10
| GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOE,&GPIO_InitStructure);
/* FSMC_D13 ~ FSMC_D15 PD8 ~ PD10 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
FSMC_A0 ~ FSMC_A5 FSMC_A6 ~ FSMC_A9
PF0 ~ PF5 PF12 ~ PF15
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3
| GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOF,&GPIO_InitStructure);
/* FSMC_A10 ~ FSMC_A15 PG0 ~ PG5 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
GPIO_Init(GPIOG,&GPIO_InitStructure);
/* FSMC_A16 ~ FSMC_A18 PD11 ~ PD13 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
/* RD-PD4 WR-PD5 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
/* NBL0-PE0 NBL1-PE1 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
/* NE1/NCE2 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
/* NE2 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
/* NE3 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
/* NE4 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
static void LCD_FSMCConfig(void)
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef p;
/*-- FSMC Configuration ------------------------------------------------------*/
p.FSMC_AddressSetupTime = 2; /* 地址建立时间 */
p.FSMC_AddressHoldTime = 1; /* 地址保持时间 */
p.FSMC_DataSetupTime = 3; /* 数据建立时间 */
p.FSMC_BusTurnAroundDuration = 0; /* 总线返转时间 */
p.FSMC_CLKDivision = 0; /* 时钟分频 */
p.FSMC_DataLatency = 0; /* 数据保持时间 */
p.FSMC_AccessMode = FSMC_AccessMode_A; /* FSMC 访问模式 */
/* Color LCD configuration ------------------------------------
LCD configured as follow:
- Data/Address MUX = Disable
- Memory Type = SRAM
- Data Width = 16bit
- Write Operation = Enable
- Extended Mode = Enable
- Asynchronous Wait = Disable */
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4;
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);
| 有奖活动 | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
