1820部分代码:
*Function:向18B20写入一个字节
*parameter:
*Return:
*Modify:
void WriteByte (unsigned char wr) //单字节写入
unsigned char i;
for (i=0;i<8;i++)
GPIO_ResetBits(GPIOA , D18B20); //D18B20 = 0;
Delay_us(2);
//D18B20=wr&0x01;
if(wr&0x01) GPIO_SetBits(GPIOA , D18B20);
else GPIO_ResetBits(GPIOA , D18B20);
Delay_us(45); //delay 45 uS //5
GPIO_SetBits(GPIOA , D18B20); //D18B20=1;
wr >>= 1;
*Function:读18B20的一个字节
*parameter:
*Return:
*Modify:
unsigned char ReadByte (void) //读取单字节
unsigned char i,u=0;
for(i=0;i<8;i++)
Delay_us (2);
u >>= 1;
GPIO_SetBits(GPIOA , D18B20); //D18B20 = 1;
Delay_us (4);
if(GPIO_ReadInputDataBit(GPIOA , D18B20) == 1)
u |= 0x80;
Delay_us (65);
return(u);
*Function:读18B20
*parameter:
*Return:
*Modify:
void read_bytes (unsigned char j)
unsigned char i;
for(i=0;i<j;i++)
*p = ReadByte();
p++;
*Function:CRC校验
*parameter:
*Return:
*Modify:
unsigned char Temp_CRC (unsigned char j)
unsigned char i,crc_data=0;
for(i=0;i<j;i++) //查表校验
crc_data = CrcTable[crc_data^temp_buff[i]];
return (crc_data);
*Function:读取温度
*parameter:
*Return:
*Modify:
void GemTemp (void)
read_bytes (9);
if (Temp_CRC(9)==0) //校验正确
Temperature = temp_buff[1]*0x100 + temp_buff[0];
// Temperature *= 0.625;
Temperature /= 16;
Delay_us(10);
*Function:内部配置
*parameter:
*Return:
*Modify:
void Config18b20 (void) //重新配置报警限定值和分辨率
Init18b20();
WriteByte(0xcc); //skip rom
WriteByte(0x4e); //write scratchpad
WriteByte(0x19); //上限
WriteByte(0x1a); //下限
WriteByte(0x7f); //set 12 bit (0.125)
Init18b20();
WriteByte(0x48); //保存设定值
Init18b20();
WriteByte(0xb8); //回调设定值
*Function:读18B20ID
*parameter:
*Return:
*Modify:
void ReadID (void)//读取器件 id
Init18b20();
WriteByte(0x33); //read rom
read_bytes(8);
*Function:18B20ID全处理
*parameter:
*Return:
*Modify:
void TemperatuerResult(void)
p = id_buff;
ReadID();
Config18b20();
Init18b20 ();
WriteByte(0x44); //Temperature convert
Init18b20 ();
WriteByte(0xbe); //read Temperature
p = temp_buff;
GemTemp();
void GetTemp()
if(Count == 3) //每隔 3s 读取温度
{ Count=0;
TemperatuerResult();
