电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » DS2422 Trim Procedure and Software Corre
DS2422 Trim Procedure and Software Correction
2012-04-03 22:58:35     打赏
关键词: DS2422, trim, correction, conversion, accuracy, error, reference, temperature, spreadsheet, conversion length, temperature reset value, CLEN, Treset
Abstract: Before it can accurately measure temperatures, the DS2422 needs to undergo a two-point trim. For the highest level of accuracy, this trim needs to take place as late as possible, i.e., with the end product that the DS2422 resides in. The accuracy can be further improved through software correction if actual values and temperature readings of the DS2422 at additional temperature points are stored in the calibration memory. This application note describes how to perform the trim, how to obtain, format and store the data for the software correction and how to perform the software correction. A spreadsheet with calculations and format conversions used in this application note can be downloaded from www.ibutton.com.
 DS2422 Trim Procedure and Software Correction.pdf
关键词: DS2422     Procedure     Software
