电子产品世界 » 论坛首页 » 综合技术 » 测试测量 » 力科逻辑分析仪解决方案
力科逻辑分析仪解决方案
2012-04-13 19:55:18     打赏
LogicStudio
逻辑分析仪是众所周知的速度慢,结构复杂、价格昂贵的仪器,但是 LogicStudio通过其强大的特性,高性能的硬件和直观的点击式用户界面改变了这一切。
Lively, Dynamic Display
LogicStudio is fast! Waveforms update quickly and panning or zooming is extremely responsive. Download the software and experience it yourself. Download
Sleek and Sophisitcated User Interface
The software interface is modern and intuitive creating a new logic analyzer experience.
Simple Mouse Operation
LogicStudio is intuitive and easy to operate with friendly left-click and right-click controls plus all buttons are on the main screen, no complicated menus to navigate.
MSO PC capabilities
LogicStudio is compatible with 10 popular oscilloscopes series from LeCroy, Tektronix and Agilent covering bandwidths from 40 MHz up to 1 GHz. Connecting the instruments is easy with the included USB and BNC cables, make the connections and let the software establish the link and begin displaying waveforms.
Protocol Decoding and Data Trigger
View decoded protocol information for I2C, SPI and UART busses plus trigger on data being transmitted on the serial busses.
Cursors
Quickly measure the time between transitions on a single line, across digital lines or from a digital line to an analog waveform. Snap the cursors directly to the waveform edge for precise measurements.
Waveform Magnifier
Get a better view of the waveforms by passing over them with the magnifier, scroll the mouse wheel to zoom in for an even closer look.
History
Did something interesting or surprising just flash across the screen, stop the trigger and flip through a history of the previous 100 acquisitions.
Powerful Triggering
For difficult problems a simple edge or logic level trigger is not enough. LogicStudio advanced triggering provides an environment for creating powerful combinations of edge, logic level, parallel bus and serial bus triggers to isolate difficult problems.
Persistence
View variations in the signals over time to find problems faster. Use with History mode to see what happened when and isolate the problem.
Interleaving for Higher Performance
Use all 16 channels at 500 MS/s or 8 channels at 1 GS/s for more timing resolution
Logic Thresholds
Choose from standard TTL and CMOS levels or create a custom level from 0 ¨C 7 V
Trigger Modes
Oscilloscope trigger modes of Auto, Normal and Single help ensure what you need to see is always on the display.
Save and Recall
Save screenshots to share with others or save waveforms and setups for recalling later.
Add/Remove/Hide Waveforms
One click to add a new waveform, one click to remove it, right-click to hide it.
Configure and Name
Double click a channel to enter a custom name or click the Signals button to change the color or signal to display
Freeform Display
View waveforms stacked on top of each other or enable Freeform display to overlay one waveform on top of another .
Built-In Getting Started Manual
Not sure how to use a certain tool, mouse over for tool tips or access the manual from the Help menu.
Tell LeCroy
Have a question or suggestion? Click on Tell LeCroy in the Help menu and send an email directly to LeCroy with the waveforms, screen capture and setup file attached to the message.
关键词: 力科     逻辑     分析仪     解决方案
