电子产品世界 » 论坛首页 » 综合技术 » 测试测量 » 串行AudioBus
串行AudioBus
2012-04-13 20:35:21     打赏
AudioBus - I2S
LeCroy’s Serial AudioBus trigger, decode, and graph package provides all the tools needed to properly analyze and debug digital audio buses. LeCroy’s solution addresses the I2S, LJ, RJ, and TDM variations of the audio bus standard.
Key Features
  • Supports:
    • Inter-IC Sound (I2S)
    • Left Justified (LJ)
    • Right Justified (RJ)
    • Time Division Multiplex (TDM)
  • Display digital audio serial data as an analog waveform
  • Hex, Binary, Decimal, and dB Decoding
  • Color-coded decode overlaid on the waveform is intuitive and easy to read
  • Powerful and flexible conditional DATA triggering (=, <, <=, >, >=, <>, in range, out of range)
  • Trigger on glitch, clip, and mute
  • Decode information expands as the timebase is adjusted or zoomed
  • Convenient table displays up to 4 channels with quick “zoom to message” capability
  • Quick search capability for specific messages
  • Decode up to 4 simultaneous traces, including both right and left channels
  • Decode does not require clock trace to be displayed
View Audio Waveforms
LeCroy’s Audiobus decode enables the unique View Audio feature that converts the digitally-encoded serial data audio signal into an analog waveform display. This provides an intuitive way to understand circuit problems causing clipping, glitches, and other anomalies in the audio circuit. It also helps show the effects of the audio signal before Digital Signal Processing (DSP). View Audio can be performed for up to four audio channels for conventional Left/Right audio, or home cinema applications (enabled by time division multiplexed audio buses).
The Most Intuitive Decode
Audiobus uses color-coded overlays on various sections of the protocol decode for an easy-to-understand visual display. This LeCroy exclusive feature is intuitive to experienced audio engineers and especially useful for users new to the I2S, LJ, RJ, or TDM Audiobus standards. The decode information condenses or expands depending on the timebase/ zoom ratio setting, simplifying both routine verification and complex troubleshooting. Choose to decode into Hex, Binary, Decimal, or dB formats.
Powerful Conditional Data Triggering
The Audiobus trigger can be configured for I2S, LJ, or RJ variants. Powerful conditional triggering can be applied to either left or right channel data, while unique triggers like mute, clip, and glitch help isolate rare problems not easily detected by viewing decoded data alone.
Flexible Triggering
The Audiobus trigger can be configured for I2S, LJ, or RJ variants. Powerful conditional triggering can be applied to either left or right channel data, while unique triggers like mute, clip and glitch help to isolate rare problems not easily detected by viewing decoded data alone.
Convenient Table Display Summarizes Results
Turn your oscilloscope into a protocol analyzer with the Table display of protocol information. Custom configure the Table to display only the infor mation you want, and export Table data to an Excel file. Touch a message in the table and auto matically zoom for detail. In all cases, the Table never obscures your waveform data.
Search and Zoom
Audiobus messages can be quickly located by search ing on message or pattern. Pressing an arrow button advances the single zoomed message view one message to the right or left of the current message.
Specifications
  AudioBus TD  AudioBus TDG
  Definition
Protocol Setup
DATA Select MSB or LSB (TDM only) Select Length (8, 12, 16, 18, 20, 24, 28, or 32-bits) Select Justification (Left or Right justified with respect to frame sync’s transition) Select Start bit (TDM only)
SYSTEM BIT CLOCK POLARITY
Select data latch on Rising (1) or Falling (0) edge
WORD SELECT (FRAME SYNCH)
Select Word Length (8, 12, 16, 18, 20, 24, or 32-bits long) or Bit Length (one bit long) Select Frame Start (High or Low) Select Alignment (Together with Data Word (Right Justified or Left Justified), or 1-bit Earlier (I2S) )
Also, may select I2S, Left Justified, Right Justified, or TDM default setups.
DATA Select MSB or LSB (TDM only) Select Length (8, 12, 16, 18, 20, 24, 28, or 32-bits) Select Justification (Left or Right justified with respect to frame sync ''s transition) Select Start bit (TDM only)
  View Audio Waveform
Format N.A.  For I2S, LJ, RJ:
View Left, Right, or both analog channels
For TDM mode:
View channels 1–8
  Decode Capability
Format Hexadecimal, Binary, Decimal, dB.  Hexadecimal, Binary, Decimal, dB.
 Decode Setup   Threshold definition required. Default is to Percent amplitude.  Threshold definition required. Default is to Percent amplitude.
 Decode Input   Any analog Channel, digital Channel (MS-250 or MS-500), Memory or Math trace. Clock and/or FrameSynch/Word Select channel may be turned OFF and data will still decode (reduces screen clutter).  Any analog Channel, digital Channel (MS-250 or MS-500), Memory or Math trace.
 # of Decoded Waveforms   Up to 4 buses may be decoded at one time. In addition, zooms can be displayed (with decoded information).  Up to 4 buses may be decoded at one time. In addition, zooms can be displayed (with decoded information).
 Location   Overlayed over DATA waveform, on Grid.  Overlayed over DATA waveform, on Grid.
 Visual Aid   Color Coding for right Channel and left Channel. (Ch 1–8 for TDM) Decode information is intelligently annotated based on timebase setting.  Color Coding for right Channel and left Channel. (Ch 1–8 for TDM)
  Trigger Capability
 Format   Hexadecimal, Binary.  Hexadecimal, Binary.
 Trigger Setup   Trigger on DATA, Clip, Glitch, Mute.  Trigger on DATA, Clip, Glitch, Mute.
 DATA Condition Setup   <=, <, =, >, >=, <>, in range, out of range, don’t care.  <=, <, =, >, >=, <>, in range, out of range, don’t care.
 DATA Setup   Hexadecimal: # Data Bits = 1 to 32.
Data can be defined by nibble.
Binary: Any combination of 0,1, or X for 1–32-bits in 4-bit increments.
 Bit Rates    Any. Auto-detected.    Any. Auto-detected.
 Trigger Input    I2S, LJ, and RJ only.
Any analog or digital (MS-250 or MS-500) Channel or the EXT input. Clock or Frame Synch/Word Select may be input to EXT to conserve available analog Channels.
 Trigger Design    Internal to oscilloscope, settable like any other oscilloscope trigger.    Internal to oscilloscope, settable like any other oscilloscope trigger.
  Search Capability
 Pattern Search    Search by message or pattern in hexadecimal formats.    Search by message or pattern in hexadecimal formats.
   Oscilloscope Capability
 Compatible With…    TD (Trigger and Decode) Option fully compatible with WaveRunner® Xi/Xi-A, WaveSurfer® Xs/Xs-A.    TDG (Trigger, Decode and Graph) Option fully compatible with WaveRunner® Xi/Xi-A
关键词: 串行     AudioBus     audio     Justifi
