共7条
编译错误,请帮忙啊
ccarm -mapcs-32 -mlittle-endian -march=armv4 -nostdi
nc -O2 -fno-builtin -fvolatile -Wall -I/h -I. -IC:\Tornado_ARM\target\config\a
ll -IC:\Tornado_ARM\target/h -IC:\Tornado_ARM\target/src/config -IC:\Tornado_ARM
\target/src/drv -DCPU=ARMARCH4 -DTOOL_FAMILY=gnu -DTOOL=gnu -DARMEL -I../../../
CODE/INCLUDE -I../../../CODE/SSP/INCLUDE -I../../../CODE/MAINTAIN/INCLUDE -I../.
./../CODE/PLATFORM/INCLUDE -I../../../CODE/URP/INCLUDE/PUB -I../../../CODE/URP/I
NCLUDE/PRIVATE -g -DDEV_TYPE=0xFFFF -DVERSION_TYPE=2 -DEOS_OS_TYPE=2 -DEOS_CPU_T
YPE=5 -O2 -DRW_MULTI_THREAD -D_REENTRANT -fvolatile -fno-builtin -fno-for-scope
-Wall -Woverloaded-virtual -Wcast-qual -c ../../../CODE/SSP/RDB/
Trans/Rdb_TransTable.cpp -o obj/Rdb_TransTable.o
In file included from C:/Tornado_ARM/target/h/new.h:6,
from C:/Tornado_ARM/target/h/stl_algobase.h:52,
from C:/Tornado_ARM/target/h/stl_tree.h:56,
from C:/Tornado_ARM/target/h/map:31,
from ../../../CODE/SSP/RDB/Rdb_Common.h:34,
from ../../../CODE/SSP/RDB/Trans/Rdb_TransTable.cpp:36:
C:/Tornado_ARM/target/h/new:32: `operator new' takes type `size_t' as first para
meter
C:/Tornado_ARM/target/h/new:33: `operator new' takes type `size_t' as first para
meter
C:/Tornado_ARM/target/h/new:36: `operator new' takes type `size_t' as first para
meter
C:/Tornado_ARM/target/h/new:37: `operator new' takes type `size_t' as first para
meter
C:/Tornado_ARM/target/h/new:42: `operator new' takes type `size_t' as first para
meter
C:/Tornado_ARM/target/h/new:43: `operator new' takes type `size_t' as first para
meter
make.exe: *** [obj/Rdb_TransTable.o] Error 0x1
make.exe: *** No rule to make target `target_all'. Stop.
关键词: 编译 错误 帮忙 Tornado target
共7条
