电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 【应用手册】AN 557: Stratix III-to-Stratix IV
【应用手册】AN 557: Stratix III-to-Stratix IV E Cross-Family Migration Guidelines
2012-04-30 10:05:22     打赏
This application note provides guidelines in cross-family migration designs between
the Altera® Stratix® III and Stratix IV E device family variant using the Quartus® II
software. Use these guidelines for drop-in replacement of either device placed on a
single PCB through your hardware design. Altera recommends using the following
guidelines throughout your PCB design process to ensure a seamless migration of
designs from Stratix III-to-Stratix IV E devices.
You can design your Stratix III FPGAs to take advantage of the higher performance,
higher density, and lower power benefits of Stratix IV E FPGAs. With up-front
planning that considers the different power supply voltages and available packages in
both families, it is possible to design a PCB assembled with either a Stratix III or a
Stratix IV E device in the same package.
Cross-family migration between Stratix III and Stratix IV E FPGAs allows you to
design with Stratix III FPGAs today and move to Stratix IV E FPGAs in the future
without changing the device pin-outs or the PCB layout.an557.pdf
关键词: 应用     手册     Stratix     III-to-Stra
