关于CAN中断发送被挂起,已经解决问题
#include "stm32f10x.h"
//#include "USART.h"
#include "delay.h"
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
ErrorStatus HSEStartUpStatus;
unsigned char TestTx; //发送成功标志
unsigned char CAN_MessageSend(void); //报文发送函数
void GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOE, &GPIO_InitStructure);
GPIO_PinRemapConfig(GPIO_Remap1_CAN1, ENABLE ); //重影射CAN IO脚到 PB8,PB9
/* Configure CAN pin: RX */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Configure CAN pin: TX */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_SetBits(GPIOE, GPIO_Pin_2);
GPIO_SetBits(GPIOE, GPIO_Pin_3);
GPIO_SetBits(GPIOE, GPIO_Pin_4);
GPIO_SetBits(GPIOE, GPIO_Pin_5);
//系统中断管理
void NVIC_Configuration(void)
// NVIC_InitTypeDef NVIC_InitStructure;
/* Configure the NVIC Preemption Priority Bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
// /* enabling interrupt */
// NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
// NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
// NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
// NVIC_Init(&NVIC_InitStructure);
//配置系统时钟,使能各外设时钟
void RCC_Configuration(void)
SystemInit();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA
|RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
|RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
|RCC_APB2Periph_ADC1 | RCC_APB2Periph_AFIO
|RCC_APB2Periph_SPI1, ENABLE );
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL ,ENABLE );
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4
|RCC_APB1Periph_USART3|RCC_APB1Periph_TIM2
, ENABLE );
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
//配置所有外设
void Init_All_Periph(void)
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration();
int main(void)
Init_All_Periph();
while(1)
/* CAN transmit at 100Kb/s and receive by polling in normal mode */
TestTx = CAN_MessageSend();
if (TestTx == 1)
GPIO_ResetBits(GPIOE,GPIO_Pin_5);
delay_nms(1000); // LED1闪烁一次,发送一个字符
GPIO_SetBits(GPIOE,GPIO_Pin_5);
delay_nms(1000);
CAN_InitTypeDef CAN_InitStructure;
CanTxMsg TxMessage;
volatile u8 TransmitMailbox = 0;
u32 i;
/* CAN register init */
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
/* CAN cell init */
CAN_InitStructure.CAN_TTCM=DISABLE; //禁止时间触发通讯模式
CAN_InitStructure.CAN_ABOM=DISABLE; //禁止自动离线模式
CAN_InitStructure.CAN_AWUM=DISABLE; //禁止自动唤醒模式
CAN_InitStructure.CAN_NART=ENABLE; //自动重传模式
CAN_InitStructure.CAN_RFLM=DISABLE; //禁止接收FIFO锁定模式,当接收FIFO的报文未被读出,下一个收到的报文会覆盖原有的报文
CAN_InitStructure.CAN_TXFP=DISABLE; //禁止发送FIFO优先级,优先级由报文的标识符来决定
CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;//CAN硬件工作在正常模式
CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;//重新同步跳跃宽度1个时间单位
CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;//时间段1为8个时间单位
CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;//时间段2为7个时间单位
CAN_InitStructure.CAN_Prescaler=5; // (pclk1/((1+8+7)*9)) = 36Mhz/[(CAN_SJW_1tq+CAN_BS1_8tq+CAN_BS2_7tq)*(CAN_Prescaler)] = 100Kbits
// 设定了一个时间单位的长度
CAN_Init(CAN1,&CAN_InitStructure);
/* transmit 1 message */
TxMessage.StdId=0x01;
//TxMessage.ExtId=0x1234;
TxMessage.IDE=CAN_ID_STD;//使用标准格式,扩展格式为:TxMessage.IDE=CAN_ID_EXT;
TxMessage.RTR=CAN_RTR_DATA; //数据帧
TxMessage.DLC=1;
TxMessage.Data[0]=0xDE;
//TxMessage.Data[1]=0xCA;
/*数据发送*/
TransmitMailbox = CAN_Transmit(CAN1,&TxMessage);
i = 0;
while((CAN_TransmitStatus(CAN1,TransmitMailbox) != CANTXOK) && (i != 0xFF)) //等待CAN总线传输数据成功
i++;
if(i==0xff)//发送超时,但发送不成功
GPIO_ResetBits(GPIOE,GPIO_Pin_4);
GPIO_SetBits(GPIOE,GPIO_Pin_4);
delay_nms(1000);
return 0;
return 1;
1、你用的是中断发送么还是??请检查一下,如果是中断的话就看看中断入口!或者是修改中断服务入口
2、检查一下CAN总线的IO口对与否,是不是映射了还是没有映射!!
3、建议设置一下掩码地址
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 | |
汽车电子中巡航控制系统的使用被打赏10分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏100分 |
