This white paper provides an overview of the RealDigital technology used in Xilinx CoolRunner™-II CPLDs. RealDigital is the patented design technology used in Xilinx CoolRunner-II CPLDs that enable highperformance and ultra low power consumption in programmable logic devices. RealDigital is a key technology for CoolRunner-II CPLDs that minimizes system current demand and allows small chip-scale packaging options. Low-power designs are enabled through RealDigital by using true CMOS both in process technology and design technique.
wp171.pdf
共1条
CoolRunner-II 真正数字化技术
关键词: CoolRunner-II 真正 数字化 技术
共1条
