This application note describes how to use the Virtex®-5 FPGA input/output delay (IODELAY) primitive as a means to create a high-precision adjustable oscillator with a wide tuning range. Three different use models are described for the adjustable oscillator:
xapp872.pdf
共1条
为Virtex-5FPGA IODELAY创建一个原始的可控振荡器
关键词: Virtex-5FPGA IODELAY 创建 一
共1条
