The PCI™ Local Bus Specification defines a number of power and reset requirements. When considered in an FPGA implementation, these create several challenges that must be addressed for long term reliability and broad interoperability. This application note applies to compliant PCI applications using Spartan™-3 Generation FPGAs, and is relevant to other Xilinx FPGA families, as well as related PCI applications.
xapp457.pdf
共1条
Spartan-3代fpga驱动和配置符合PCI的应用
关键词: Spartan-3 驱动 配置 符合 应用
共1条
