This application note discusses the Serial Peripheral Interface (SPI) configuration mode introduced in the Virtex®-5 and Spartan®-3E FPGA families. The ISE® Design Suite with iMPACT in-system programming solution with Xilinx cables for prototype designs is also described.
xapp951.pdf
共1条
通过SPI串口Flash配置Xilinx FPGAs
关键词: 通过 串口 Flash 配置 Xilinx FPG
共1条
