P/IP is a communication protocol stack designed to provide a reliable data stream between two hosts. It is a popular means of communicating data over a network. Most people use the protocol every day to check email, browse the web, instant message, and download files. TCP/IP is also becoming more utilized in embedded systems. This application note explores the use of an open source TCP/IP stack on the Virtex-II™ Pro PowerPC™ processor. An example reference design is provided allowing remote interaction with the peripherals on the Insight/Memec designed Virtex-II Pro development board. This product is not recommended for new designs.
xapp655.pdf
共1条
TCP/IP on Virtex-II Pro Devices Using lwIP - Not Recommended for New Designs
共1条
