This application note shows how a Xilinx Virtex™-II or Virtex-II Pro device can connect to a Philips TZA3015HW 30 Mbit/s to 3.2 Gbit/s A-rate 4-bit fibre optic transceiver. The reference design with this application note uses the TZA3015HW. This product is not recommended for new designs.
xapp764.pdf
共1条
Connecting Xilinx FPGAs to the Philips A-rate Fibre Optic Transceiver - Not Reco
关键词: Connecting Xilinx FPGAs P
共1条
