The non-integer data recovery unit (NI-DRU) presented in this application note is specifically designed for RocketIO™ GTP and GTX transceivers in Virtex®-5 LXT, SXT, TXT, and FXT platforms and consists of look-up tables (LUTs) and flip-flops. The NI-DRU extends the lower data rate limit to 0 Mb/s and the upper limit to 1,250 Mb/s, making embedded high-speed transceivers the ideal solution for true multi-rate serial interfaces.
xapp875.pdf
共1条
Dynamically Programmable DRU for High-Speed Serial I/O
关键词: Dynamically Programmable
共1条
