This application note targets Spartan®-3E/3A devices in applications that require 4-bit or 5-bit receive data bus widths and operate at rates up to 666 Mbps per line with a clock at 1/7th the bit rate. This type of interface is commonly used in flat panel displays and automotive applications.
xapp485.pdf
共1条
1:7 Deserialization in Spartan-3E/3A FPGAs at Speeds Up to 666 Mbps
关键词: Deserialization Spartan-3
共1条
| OrangePiZero2W系统被打赏¥33元 | |
