This application note targets Spartan™-3E devices in applications that require 4-bit or 5-bit transmit data bus widths and operate at rates up to 666 Mbps per line with a forwarded clock at 1/7th the bit rate. This type of interface is commonly used in flat panel displays and automotive applications.
xapp486.pdf
共1条
7:1 Serialization in Spartan-3E/3A FPGAs at Speeds Up to 666 Mbps
关键词: Serialization Spartan-3E
共1条
| OrangePiZero2W系统被打赏¥33元 | |
