This application note describes a cost-optimized copy protection scheme that helps protect an FPGA against cloning. The design leverages an external secure serial EEPROM. The included reference design uses an optimized PicoBlaze™ 8-bit microcontroller. This application note provides a hardware design with associated PicoBlaze software code. The code loads a secret key into the secure EEPROM and authenticates the user system with the secure EEPROM.
xapp780.pdf
共1条
FPGA IFF Copy Protection Using Dallas Semiconductor/Maxim DS2432 Secure EEPROMs
关键词: Protection Using Dallas S
共1条
| OrangePiZero2W系统被打赏¥33元 | |
