This application note describes how to indirectly program select BPI PROMs through the JTAG interface of a Virtex®-5 FPGA using iMPACT. The required hardware setup, BPI-UP PROM file generation, and the indirect programming flow are described.
xapp973.pdf
共1条
Indirect Programming of BPI PROMs with Virtex-5 FPGAs
关键词: Indirect Programming PROM
共1条
