This application note describes how to indirectly program an SPI Serial Flash PROM through the JTAG interface of a Spartan®-3A FPGA using iMPACT 9.1.01i. The hardware setup, software flows for file generation, and programming are also covered.
xapp974.pdf
共1条
Indirect Programming of SPI Serial Flash PROMs with Spartan-3A FPGAs
关键词: Indirect Programming Seri
共1条
