The ITU-G.709 standard for error correction is examined and implemented in both the Virtex™-4 and Virtex-5 Platform FPGA families using the LogiCORE™ Reed-Solomon (RS) Encoder and Decoder cores.
xapp952.pdf
共1条
Forward Error Correction on ITU-G.709 Networks using Reed-Solomon Solutions
共1条
