电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 【应用笔记】使用样例驱动在硬件上测试DDR SDRAM接口(Test DDR S
【应用笔记】使用样例驱动在硬件上测试DDR SDRAM接口(Test DDR SDRAM Interfaces on Hardware Using the Ex
2012-05-20 17:34:26     打赏
【应用笔记】使用样例驱动在硬件上测试DDR SDRAM接口(Test DDR SDRAM Interfaces on Hardware Using the Example Driver)
本应用笔记描述了如何在Altera开发板使用AlteraDDR SDRAM控制器MegaCore功能模块产生的样例驱动,来测试DDR SDRAM接口。
This application note describes how to test DDR SDRAM interfaces on
Altera® development boards using the Altera DDR SDRAM Controller
MegaCore® function-generated example driver. The example driver—a
stand-alone synthesizable circuit—demonstrates the DDR SDRAM
interface. You can use these instructions to quickly build a DDR SDRAM
interface on one of the Altera boards and see it working; or use the same
principles to establish whether the DDR SDRAM interface on your board
is working as expected, independently of any other circuit.an380.pdf
关键词: 应用     笔记     使用     样例     驱动     硬件     测试     SDRA
