*  标题:  步进电机试验五(正转一圈 反转一圈)            *
*    通过本例程了解步进马达使用及驱动程序编写            *
*;   单双八拍工作方式:                                                            *
*;   A-AB-B-BC-C-CD-D-DA (即一个脉冲,转 3.75 度)                *
*  请学员一定要消化掉本例程                                                       *
 #include "reg52.h"
void delay(unsigned int t);
 //Motor
sbit F1 = P1^0;
sbit F2 = P1^1;
sbit F3 = P1^2;
sbit F4 = P1^3;
unsigned char code FFW[8]={0xfe,0xfc,0xfd,0xf9,0xfb,0xf3,0xf7,0xf6}; //反转
unsigned char code FFZ[8]={0xf6,0xf7,0xf3,0xfb,0xf9,0xfd,0xfc,0xfe}; //正转
unsigned int  K;
*                       步进电机驱动          *
void  motor_ffw()
   unsigned char i;
   unsigned int  j;
   for (j=0; j<12; j++)         //转1*n圈
      for (i=0; i<8; i++)       //一个周期转30度
          if(K==1) P1 = FFW[i]&0x1f;  //取数据
    if(K==2) P1 = FFZ[i]&0x1f;
          delay(5);                   //调节转速
*              延时程序
   unsigned int k;
   while(t--)
     for(k=0; k<80; k++)
main()
    while(1)
  K=1;
  motor_ffw();
  K=2;
  motor_ffw();
