This application note and reference design gives examples of a typical spread-spectrum clock for video applications using the Spartan®-6 FPGA DCM_CLKGEN primitive. DCM_CLKGEN can be used for fixed spread-spectrum generation without any logic or in a soft spread-spectrum solution using a state machine.
xapp1065.pdf
共1条
新代扩频时钟Spartan-6FPGAs
关键词: 新代 扩频 时钟 Spartan-6FPGAs
共1条
