//中断代码
void USART1_IRQHandler(void)
static u8 i=0;
delay(0xfffff);
//中断接收数据
if(i%2)
GPIO_SetBits(GPIOE, GPIO_Pin_4);
else
GPIO_ResetBits(GPIOE, GPIO_Pin_4);
i++;
//接收数据
ch[count] = USART1_Getchar();
//USART1_Putchar(ch[count]);
count ++;
if(ch[count] == 0)
flag = SET;
USART_ClearITPendingBit(USART1, USART_IT_ORE);
//停止中断
if(count > 50)
//flag = SET;
//USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
count = 0;
//各种配置
void USART_Configure()
USART_InitTypeDef USART_InitStruct;
USART_ClockInitTypeDef USART_ClockInitStruct;
GPIO_InitTypeDef GPIO_InitStruct;
USART_InitStruct.USART_BaudRate = 9600;
USART_InitStruct.USART_StopBits = USART_StopBits_1;
USART_InitStruct.USART_Parity = USART_Parity_No;
USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStruct);
USART_ClockInitStruct.USART_Clock = USART_Clock_Disable;
USART_ClockInitStruct.USART_CPOL = USART_CPOL_High;
USART_ClockInitStruct.USART_CPHA = USART_CPHA_1Edge;
USART_ClockInitStruct.USART_LastBit = USART_LastBit_Disable;
USART_ClockInit(USART1, &USART_ClockInitStruct);
//使能USART1
USART_Cmd(USART1, ENABLE);
//使能接收中断中断
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
//使能DMA发送
USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);
DMA_Cmd(DMA1_Channel4, ENABLE);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING;
void NVIC_Configure()
NVIC_InitTypeDef NVIC_InitStruct;
//NVIC_SetVectorTable(NVIC_VectTab_RAM,0x0);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
NVIC_InitStruct.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStruct);
void DMA_Configure()
DMA_InitTypeDef DMA_InitStruct;
DMA_InitStruct.DMA_PeripheralBaseAddr = tUSART1_DR_Base;
DMA_InitStruct.DMA_MemoryBaseAddr = (uint32_t)ch;
DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStruct.DMA_BufferSize = sizeof(ch) / sizeof(ch[0]);
DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
DMA_InitStruct.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
DMA_InitStruct.DMA_Mode = DMA_Mode_Normal;
DMA_InitStruct.DMA_Priority = DMA_Priority_VeryHigh;
DMA_InitStruct.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel4, &DMA_InitStruct);
