用KEIL 进行仿真----BSRR BRR----不正常显示求解
#include "stm32f10x.h"
#include "LED.h"
void Key_Init(void);
int main(void)
Led_TypeDef led=LED2;
Key_Init();
LED_Init(led);
while(1)
GPIO_SetBits (GPIOE, led) ;
if(GPIO_ReadInputDataBit (GPIOF, GPIO_Pin_11)==0)
LED_Set(led, ON);
else
//LED_Set(led, OFF);
GPIO_SetBits (GPIOE, led) ;//这个函数不就是操作BRR的吗?仿真值不变,挺奇怪
#include "LED.h"
int main(void)
Key_Init();
LED_Init(led);
while(1)
LED_Set(led, ON);
else
在这里,你稍微帮着看一下
void Key_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
/* GPIOD Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE);
/* Configure PF11 in GPIO_Mode_IPU mode 上拉输入*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIOF, &GPIO_InitStructure);
void LED_Init(Led_TypeDef led)
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG, ENABLE);
GPIO_InitStructure.GPIO_Pin=led;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;//配置GPIO速度为50MHz
GPIO_Init(LED_GPIO_PORT,&GPIO_InitStructure);//初始化LED相关的GPIO
// GPIO_InitStructure.GPIO_Pin=GPIO_Pin_All;
GPIO_Init(GPIOE,&GPIO_InitStructure);
//GPIO_Init(GPIOA,&GPIO_InitStructure);
