使用ISE编译一个verilog HDL代码文档出现如下警告:
WARNING:Xst:737 - Found 8-bit latch for signal <count>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
该文档内容如下:
module operation(
input rst_n,
input add,
input subtract,
output [7:0] q
reg [7:0] count;
always @ (add or subtract or rst_n)
begin
if(!rst_n)
count <= 0;
else if(!add)
count <= count + 1;
else if(!subtract)
count <= count - 1;
end
assign q = count;
endmodule
请问大虾们,这个警告怎么解决呢?先谢谢了。
额~解决了,代码修改如下:
module operation(
input clk_1M,
input rst_n,
input add,
input subtract,
output [7:0] q
reg [7:0] count;
always @ (posedge clk_1M or rst_n)
begin
if(!rst_n)
count <= 0;
else if(!add)
count <= count + 1;
else if(!subtract)
count <= count - 1;
end
assign q = count;
endmodule
说明:这是一个检测按键的module。我之前写成了组合逻辑电路,现改为时序逻辑电路就对了。看来需要深入了解组合逻辑电路和时序逻辑电路的语法以及应用场合。
module operation(
input clk_1M,
input rst_n,
input add,
input subtract,
output [7:0] q
reg [7:0] count;
begin
if(!rst_n)
count <= 0;
else if(!add)
count <= count + 1;
else if(!subtract)
count <= count - 1;
end
assign q = count;
endmodule
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
