14楼
64pin的STM32本身就没有FSMC单元,所以也不可能有外部引脚了,你的仔细看看datasheet,EEPW-ARM Cortex M3 DIY资料系列之——主控MCU-STM32F103ZET6(中文).pdf:http://share.eepw.com.cn/share/download/id/61164
另外,FSMC的管脚众多,地址线与数据线分开(根本原因在于M3内核是哈佛架构)在加上控制引脚,起码都在30pin以上,64pin还要除掉10来个VCCIO&GND电源引脚,剩下的pin不多了,这样在管脚少的MCU上加FSMC也就没有多少意义了。
给你推荐一款,NUC501,用外挂SPI flash存储程序的,arm7内核,价格6.5RMB,32K内部ram,运行时引导程序将spi flash里边的程序加载到ram运行。qq:1733215976,提供样片和开发板
资源如下。
| Part No. | Core | Memory | Storage | MAC | USB | Video | GFX | LCD | Timer | Analog | Peripheral | Power | Package | Status** | ||||||||||||||||||||||||||||||
| ADC (10-bit) | ||||||||||||||||||||||||||||||||||||||||||||
| CPU Speed (MHz) | I Cache (KB) | D Cache (KB) | SRAM (KB) | Security against piracy | SDRAM | NOR Flash | SPI Flash, No. of I/O Pins | NAND Flash, No. of ECC bits | ATAPI | SD / SDIO | Ethernet 10/100 MAC | USB 1.1 Host (12 Mbps) | USB 2.0 Host (480 Mbps) | USB 2.0 FS Device | USB 2.0 HS Device | JPEG Codec | MP4 Codec | 2D Graphics | LCD Control I/F | Real-Time Clock (RTC) | PWM | No. of Channels | Speed (Samples per second) | Touch Screen Controller | 16-bit DAC Channels | LVD/LVR | JTAG | External Bus Interface | GPIO (Max) | UART | I2C | SPI | KPI | PS2 | I2S/AC97 | YUV Sensor Interface | PCI Master | Core Voltage (V) | I/O Voltage (V) | Built-in LDO | Operating Temperature* | Package | ||
| ARM7 Family | ||||||||||||||||||||||||||||||||||||||||||||
| NUC501A | 80 | - | - | 32 | Y | - | - | 2 | - | - | - | - | - | - | 1 | - | - | - | - | - | Y | 4 | 8 | 400K | - | 1 | Y | Y | - | 26 | 1 | 1 | 2 | - | - | - | - | - | 2 | 3.3 | Y | E | LQFP48 | P |
| NUC501B | 37 | 2 | LQFP64 |
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
