电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » STM32 F3系列,亮点DSP,FPU,16位ADC,程控放大
共21条 1/3 1 2 3 › 跳转至页
2012-08-05 09:43:55     打赏
STM32 F3 series of mixed-signal MCUs with DSP and FPU instructions
The STM32 F3 series of microcontrollers combines a 32-bit ARM Cortex-M4 core with a DSP and FPU instructions running at 72 MHz with advanced analog peripherals for more flexibility. This series innovates in embedded DSC design by combining a Cortex-M4 core with fast 12-bit 5 MSPS and precise 16-bit sigma-delta ADCs, programmable gain amplifiers (4 gains, 1% accuracy), fast 50 ns comparators and versatile time control units running at 144 MHz, giving optimum integration.
The STM32 F3 series allows designers to tackle mixed-signal control applications. The devices are optimized for efficient handling and processing of mixed signals in circuits such as 3-phase motor controllers, biometrics and industrial sensor outputs or audio filters. They help simplify design, cut power consumption and reduce PCB size in consumer, medical, portable fitness, system monitoring and metering applications.
Pin compatible with the STM32 F1 series, the new STM32 F3 series enlarges the STM32’s Cortex-M4 portfolio which now offers both entry-level cost with the F3 series and highest performance with the F4 series.
The STM32 F3 series includes devices with 64 to 256 Kbytes of on-chip Flash memory, up to 48 Kbytes of SRAM and is available in WLCSP66 (less than 4.3 x 4.3 mm), LQPF48, LQFP64, LQFP100 and UFBGA100 packages.
关键词: STM32     系列     亮点     16位     程控     放大
2012-08-05 10:13:34     打赏
LZ,咱能弄点中文不?
2012-08-05 10:14:19     打赏
this is new chip?
2012-08-05 15:27:31     打赏
从官网考过来的,新的芯片,中文要自己翻译,,并且词汇语法都不复杂,就偷个懒了
2012-08-05 15:31:21     打赏
是的,新出的stm32的一个系列,偏重模拟并具有相对较好的处理功能,如果价格还那么给力,应该会火
2012-08-06 11:53:44     打赏
就只有这个简介么?
2012-08-06 11:55:03     打赏
STM32的F3系列混合信号微控制器,DSP和FPU指令
F3键的STM32系列微控制器结合了32位ARM Cortex-M4的DSP和更多的灵活性与先进的模拟外设运行在72 MHz的FPU指令的核心。这一系列创新相结合,具有快速12位5 MSPS和精确的16位Σ-Δ型ADC,可编程增益放大器(4收益,1%的精度),快50 ns的比较和多才多艺的时间Cortex-M4的核心在嵌入式DSC设计控制单元运行在144兆赫,提供最佳的整合。
STM32的F3系列使设计人员能够解决混合信号控制应用。有效地处理和混合信号处理电路中,如三相电机控制器,生物识别技术和工业传感器输出或音频过滤器的设备进行了优化。他们帮助简化设计,降低功耗和减少PCB在消费,医疗,便携式健身,系统的监测和计量应用的规模。
STM32的F1系列引脚兼容,新的STM32 F3系列扩大的STM32 Cortex-M4的组合,现在同时提供入门级的成本与F3系列F4系列的最高性能。
STM32的F3系列包括64至256 KB的片上闪存的设备,到48K字节的SRAM是可在WLCSP66(小于4.3×4.3毫米),LQPF48,LQFP64,LQFP100和UFBGA100封装。
2012-08-06 13:10:27     打赏
晕,又是机器翻译吧
2012-08-06 13:11:37     打赏
手册也出来了
2012-08-06 17:28:06     打赏
是的,这种大面积的翻译得用谷歌!!至少能有60%的意思相近!
