超炫幻彩跑马灯
視頻:http://v.eepw.com.cn/video/play/id/1935
用RL78/G13 开发板做的超炫幻彩跑马灯,可以随意调整模式,速度,颜色
用了八個RGB三色共陽LED
R LED連接到P2
G LED連接到P1
B LED連接到P7
三個接鍵連接到P00/P01/P02 用于選擇模式/顏色/速度/亮度
視頻正在上傳中,稍候登場
程序如下:
定義以下文件頭:
#define KeyPort P0
#define NoKeyData 0x07
#define Key1Data 0x06
#define Key2Data 0x05
#define Key3Data 0x03
#define Key12Data 0x04
#define MODE_STEP 300
#define RedLedPort P2
#define GreenLedPort P1
#define BlueLedPort P7
#define MAX_LED_MODE 10
#define LED_OFF 0xff
#define MAX_COLOUR_MODE 8
#define MAX_SPEED 500
#define MIN_SPEED 5000
#define FLASH_SPEED_STEP 300
#define MAX_BRIGHTNESS_RATE 5
定議以下寄存器:
unsigned char LedTimerCount;
unsigned char LedOnCount;
unsigned int LedStepCount;
unsigned char Direction=0;
unsigned char LedMode;
unsigned char ColourMode;
unsigned char RedLedOnCount;
unsigned char GreenLedOnCount;
unsigned char BlueLedOnCount;
unsigned char RedPortData;
unsigned char GreenPortData;
unsigned char BluePortData;
unsigned short FLashSpeed;
unsigned char BrightnessRate;
unsigned char KeySave;
unsigned char KeyBuffer;
/***************config RGB colour*************/
const unsigned char RGBData[MAX_COLOUR_MODE][3]=
100,0,0,
80,50,10,
90,80,0,
10,100,0,
0,0,100,
10,100,20,
100,40,70,
100,100,100
LED上電初始化程序:
/******setup default mode***********/
void SetupLed(void)
ADPC=0x01;
PU7=0xff;
PM7=0x00;
PU1=0xff;
PM1=0x00;
PM2=0x00;
RedLedPort=LED_OFF; //set red off
GreenLedPort=LED_OFF; //set green off
BlueLedPort=LED_OFF; //set blueoff
LedMode=0; //set default led mode
ColourMode=1; //set default led colour
RedPortData=0x80; //set default red led status
GreenPortData=0x80; //set default green led status
BluePortData=0x80; //set default blue led status
FLashSpeed=2000; //set default flash speed
BrightnessRate=2; //set default led brightness rate
定時器中斷程序如下:
#pragma vector = INTTM00_vect
__interrupt void MD_INTTM00(void)
/* Start user code. Do not edit comment generated here */
//unsigned char Temp;
TMIF00 = 0U;
LedStepCount++;
if(LedStepCount>FLashSpeed)
LedStepCount=0;
switch (LedMode)
case 0:
RedPortData >>=1;
if(RedPortData==0x00)RedPortData=0x80;
GreenPortData >>=1;
if(GreenPortData==0x00)GreenPortData=0x80;
BluePortData >>=1;
if(BluePortData==0x00)BluePortData=0x80;
break;
case 1:
RedPortData <<=1;
if(RedPortData==0x00)RedPortData=0x01;
GreenPortData <<=1;
if(GreenPortData==0x00)GreenPortData=0x01;
BluePortData <<=1;
if(BluePortData==0x00)BluePortData=0x01;
break;
case 2:
RedPortData ^=0xff;
BluePortData ^=0xff;
GreenPortData ^=0xff;
break;
case 3:
ColourMode++;
if(ColourMode>(MAX_COLOUR_MODE-1))
ColourMode=0;
break;
case 4:
if(Direction==0)
RedPortData >>=1;
RedPortData=0x01;
Direction=1;
GreenPortData >>=1;
BluePortData >>=1;
else
RedPortData <<=1;
RedPortData=0x80;
Direction=0;
GreenPortData <<=1;
BluePortData <<=1;
break;
case 5:
RedPortData ^=0xff;
RedPortData >>=1;
RedPortData ^=0xff;
GreenPortData >>=1;
BluePortData >>=1;
break;
case 6:
if(Direction==0)
if(RedPortData==0xff)
Direction=1;
RedPortData=0xfe;
else
RedPortData >>=1;
RedPortData |= 0x80;
if(GreenPortData==0xff)
Direction=1;
GreenPortData=0xfe;
else
GreenPortData >>=1;
GreenPortData |= 0x80;
if(BluePortData==0xff)
Direction=1;
BluePortData=0xfe;
else
BluePortData >>=1;
BluePortData |= 0x80;
else
Direction=0;
RedPortData=0x80;
else
RedPortData <<=1;
Direction=0;
GreenPortData=0x80;
else
GreenPortData <<=1;
Direction=0;
BluePortData=0x80;
else
BluePortData <<=1;
break;
default:
RedPortData >>=1;
GreenPortData >>=1;
BluePortData >>=1;
break;
RedLedOnCount=RGBData[ColourMode][0];
GreenLedOnCount=RGBData[ColourMode][1];
BlueLedOnCount=RGBData[ColourMode][2];
RedLedOnCount /= BrightnessRate;
GreenLedOnCount /= BrightnessRate;
BlueLedOnCount /= BrightnessRate;
/**********PWM Timer Control*********/
LedTimerCount++;
if(LedTimerCount>100)
LedTimerCount=0;
/*****Red LED control*********/
if(LedTimerCount>=RedLedOnCount)
RedLedPort=LED_OFF; //off
else
RedLedPort=RedPortData;
/*****Green LED control*********/
if(LedTimerCount>=GreenLedOnCount)
GreenLedPort=LED_OFF; //off
else
GreenLedPort=GreenPortData;
/*****Blue LED control*********/
if(LedTimerCount>=BlueLedOnCount)
BlueLedPort=LED_OFF; //off
else
BlueLedPort=BluePortData;
按鍵處理程序:
** Abstract:
** This function initializes Key.
** Parameters:
** None
** Returns:
** None
void ConfigKey(void)
PMC0=0x00;
PU0=0xff; //set pull high
PM0=0xff; //set input
void DelayMs(unsigned short MS)
unsigned short i,j;
for(j=0;j<MS;j++)
for(i=0;i<200;i++)
** Abstract:
** This function Scan key.
** Parameters:
** None
** Returns:
** None
unsigned char ScanKey(void)
unsigned char TempData,TempData1,KeyCode;
TempData=KeyPort;
TempData &=NoKeyData;
KeyCode=NoKeyData;
if(TempData !=NoKeyData )
DelayMs(50);
TempData1=KeyPort;
TempData1 &=NoKeyData;
if(TempData==TempData1)
KeyCode=TempData;
return(KeyCode);
** Abstract:
** This function handle key function.
** Parameters:
** None
** Returns:
** None
void HandleKey(void)
KeySave=ScanKey();
if(KeySave!=KeyBuffer && KeySave==Key1Data)
LedMode++; //change LED mode
if(LedMode>MAX_LED_MODE)
LedMode=0;
switch (LedMode)
case 0: //set mode 0 default status
break;
case 1: //set mode 1 default status
RedPortData=0x01; //set default red led status
GreenPortData=0x01; //set default green led status
BluePortData=0x01; //set default blue led status
break;
case 2: //set mode 2 default status
RedPortData=0x00; //set default red led status
GreenPortData=0x00; //set default green led status
BluePortData=0x00; //set default blue led status
break;
case 3: //set mode 3 default status
break;
case 4: //set mode 4 default status
break;
case 5: //set mode 5 default status
break;
case 6: //set mode 6 default status
Direction=0;
break;
default:
break;
else if(KeySave!=KeyBuffer && KeySave==Key2Data) //change led colour
ColourMode++;
ColourMode=0;
else if(KeySave!=KeyBuffer && KeySave==Key3Data) //change flash speed
FLashSpeed +=FLASH_SPEED_STEP;
if(FLashSpeed > MIN_SPEED)
FLashSpeed=MAX_SPEED;
else if(KeySave!=KeyBuffer && KeySave==Key12Data) //change brightness
BrightnessRate++;
if(BrightnessRate > MAX_BRIGHTNESS_RATE)
BrightnessRate=1;
KeyBuffer=KeySave;
GPIO INTP/KeyBoard INT 測試
先用Applilet生基礎代碼:
在中斷程序中實現RL78/G13開發板上的LED翻轉,中斷代碼如下:
** Abstract:
** This function is INTP0 interrupt service routine.
** Parameters:
** None
** Returns:
** None
__interrupt void MD_INTP0(void)
P7 ^=0x80;
/* End user code. Do not edit comment generated here */
** Abstract:
** This function is INTKR interrupt service routine.
** Parameters:
** None
** Returns:
** None
__interrupt void MD_INTKR(void)
P7 ^=0x80;
| 有奖活动 | |
| 2026年“我要开发板活动”第三季,开始了! | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| PTC与NTC功能常规对比被打赏¥14元 | |
| 【分享开发笔记,赚取电动螺丝刀】关于3pin锂电池接口的介绍/使用被打赏¥16元 | |
| 以启明云端ESP32P4开发板实现TF卡读写功能被打赏¥28元 | |
| 【分享开发笔记,赚取电动螺丝刀】树莓派5串口UART0配置被打赏¥25元 | |
| 【STM32F103ZET6】17:分享在Rtos项目中断管理的使用经验被打赏¥23元 | |
| 【STM32F103ZET6】16:分享在中断中恢复串口任务,遇到的问题被打赏¥31元 | |
| 在FireBeetle2ESP32-C5上实现温度大气压检测及显示被打赏¥21元 | |
| 【分享开发笔记,赚取电动螺丝刀】SAME51双串口收发配置被打赏¥27元 | |
| Chaos-nano操作系统在手持式VOC检测设备上的应用被打赏¥37元 | |
| 【分享开发笔记,赚取电动螺丝刀】关于在导入第三方库lib时,wchart类型冲突的原因及解决方案被打赏¥30元 | |
