调试5:温度测定,AD数据采集
今天把AD采样程序给调试成功了。
1、图片
2、视频:
3、关键代码:
系统初始化:
void systeminit(void)
PIOR = 0x00U;
CG_ReadResetSource();
PORT_Init();
CLOCK_Init();
NOKIA_5110_init();//这里用到了显示屏
AD_Init();//AD采样的初始化
IT_Init();
CRC0CTL = 0x00U;
IAWCTL = 0x00U;
主程序:
void main(void)
/* Start user code. Do not edit comment generated here */
/* Peripheral start function calls */
IT_Start(); /* Start Interval Timer */
ADC_Init_ResultBuffer();
AD_ComparatorOn(); /* Enable ADC voltage comparator (ADCE = on) */
UINT i;
for (i=0; i < 100; i++)
NOP();
AD_Start(); /* Start ADC (ADCS = 0n) */
//显示屏的初始化显示
NOKIA_5110_write_chinese_string(0,0,12,7,0,0);//瑞萨开发板试用
NOKIA_5110_write_chinese_string(0,2,12,3,7,0);//电压
NOKIA_5110_write_chinese_string(0,4,12,3,10,0);//温度
NOKIA_5110_write_chinese_string(73,4,12,1,13,0);//度
lcdUpdateChar(2,7,'.');
lcdUpdateChar(2,13,'V');
lcdUpdateChar(4,8,'.');
/* Endless control loop */
while (1U)
/* ADC Conversions (External Voltage, Temperature and Reference Voltage) */
while (!ADIF) {} // Wait for first AD conversion completion
ADIF = 0;
temp_read = (USHORT)(ADCR >> 6U); // Ignore first ADC reading
ADC_Calculation_Ref(); // Calculate internal reference voltage value
AD_SelectADChannel(ADCHANNEL2); // Switch to external voltage (Channel 2)
NOP();
ADC_Calculation_ExtVoltage(); // Calculate external voltage value
AD_SelectADChannel(ADTEMPERSENSOR0); // Switch to temperature sensor channel
for (i=0; i < 500; i++)
NOP();
ADC_Calculation_Temp(); // Calculate temperature value
AD_SelectADChannel(ADTEMPERSENSOR1); // Switch to internal reference voltage channel
NOP();
LCD_Accel_Value2(2,6,(int)(g_voltage*1000)); //转换电压值
LCD_Accel_Value(4,6,(int)(g_temperature*100)); //转换温度
其中:
void AD_Init(void)
ADCEN = 1U; /* supply AD clock */
ADM0 = _00_AD_ADM0_INITIALVALUE; /* disable AD conversion and clear ADM0 register */
ADMK = 1U; /* disable INTAD interrupt */
ADIF = 0U; /* clear INTAD interrupt flag */
/* Set INTAD low priority */
ADPR1 = 1U;
ADPR0 = 1U;
ADPC = _04_AD_ADPC_3ANALOG;
/* Set ANI0 - ANI2 pin as analog input */
PM2 |= 0x07U;
ADM0 = _20_AD_CONVERSION_CLOCK_6 | _00_AD_TIME_MODE_STANDARD_1 | _00_AD_OPERMODE_SELECT;
ADM1 = _00_AD_TRIGGER_SOFTWARE | _00_AD_CONVMODE_CONSELECT;
ADM2 = _00_AD_POSITIVE_VDD | _00_AD_NEGATIVE_VSS | _00_AD_AREA_MODE_1 | _00_AD_RESOLUTION_10BIT;
ADUL = _FF_AD_ADUL_VALUE;
ADLL = _00_AD_ADLL_VALUE;
ADS = _81_AD_INPUT_TEMPERSENSOR_1;
void AD_Start(void)
ADMK = 0U; /* enable INTAD interrupt */
ADCS = 1U; /* enable AD conversion */
void ADC_Init_ResultBuffer(void)
UCHAR i;
for (i = 0 ; i < 10 ; i++)
ADC_result[i] = 0; // Clear ADC result buffer
void ADC_Calculation_ExtVoltage(void)
if (samples >= 3)
samples = 0;
AD_Read(&ADC_result[samples]); // Store the conversion result in the buffer
temp = (float) 1.44 / g_ref_hexvalue;
g_voltage = (float) ((ADC_result[samples] & 0xFFFC) * temp); // Calculate the external voltage value
samples++;
void ADC_Calculation_Temp(void)
if (samples >= 3)
samples = 0;
g_temperature = (float) (25 - ((((ADC_result[samples] * temp) - 1) * 1000) / 3.6)); // Calculate the temperature value in 癈
samples++;
void ADC_Calculation_Ref(void)
if (samples >= 3)
samples = 0;
g_ref_hexvalue = ADC_result[samples];
samples++;
读取数据
void AD_Read(USHORT *buffer)
*buffer = (USHORT)(ADCR >> 6U);
//选择通道
MD_STATUS AD_SelectADChannel(enum ADChannel channel)
MD_STATUS status = MD_OK;
if (((channel > ADCHANNEL7) && (channel < ADCHANNEL16)) || ((channel > ADCHANNEL19) && (channel < ADTEMPERSENSOR0)) || (channel > ADTEMPERSENSOR1))
status = MD_ARGERROR;
else
ADS = (UCHAR)channel;
return (status);
| 有奖活动 | |
| 2026年“我要开发板活动”第三季,开始了! | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| RTOS怎么选?让我来给你答案!被打赏¥15元 | |
| 【S32K3XX】Flash驱动使用被打赏¥26元 | |
| 【FreeRtos】第一个任务的启动过程被打赏¥21元 | |
| 【分享开发笔记,赚取电动螺丝刀】FPB-RA6E2开发板的WDT功能测试被打赏¥22元 | |
| 关于cmakelist特性presets的使用被打赏¥20元 | |
| 【分享开发笔记,赚取电动螺丝刀】M5STACK系列屏幕质量测试程序,竟然有块亮斑?被打赏¥20元 | |
| 【分享开发笔记,赚取电动螺丝刀】快速搭建瑞萨FPB-RA6E2开发板开发环境被打赏¥14元 | |
| 【分享开发笔记,赚取电动螺丝刀】在音频测试中顺序的调整可改变功效被打赏¥18元 | |
| 【分享开发笔记,赚取电动螺丝刀】点阵显示模块及其应用-----献给新年的小礼物被打赏¥22元 | |
| 基于地奇星开发板的数码管模块显示技术被打赏¥23元 | |
