瑞萨RL78/G13开发板验证笔记
RL78/G13开发板资料:
1、芯片:R5F100LEAFB
Price - 12-bit
A/D
Converter (ch) 0
Bit Size 16 Over
14-bit
A/D
Converter (ch) 0
Family RL78 Delta-Sigma
A/D
Converter NO
Series RL78/G1x 8-bit
D/A
Converter (ch) 0
Group RL78/G13 10-bit
D/A
Converter (ch) 0
Program
Memory (KB) 64 12-bit
D/A
Converter (ch) 0
RAM
(KB) 4 Over
14-bit
D/A
Converter (ch) 0
Data Flash (KB) 4 CAN (ch) 0
Program
Memory
Type Flash memory Ethernet NO
Cache
Memory NO Ethernet
Remarks -
Cache
Memory
Remarks - USB
Host NO
Pin Count 64 USB
Peripheral NO
CPU RL78 USB
Ports (ch) 0
Max. Freq (MHz) 32 USB
Hi-Speed
Support NO
Sub-clock
(32.768 kHz) YES USB
Endpoints 0
On-chip
Oscillator YES USB
Isochronous
Transfer
Support NO
On-chip
Oscillator
Freq. (MHz) 32M, 24M, 16M, 12M, 8M, 4M, 1M Low-speed Oscillator 15kHz USB
Remarks -
PLL NO Clocked
Serial
Interface (ch) 6
RTC YES SPI (ch) 0
Power-On Reset YES UART (ch) 3
Low Voltage Detection YES I2C (ch) 1
Memory
Management
Unit NO LIN (ch) 7
Floating Point Unit NO IEBus (ch) 0
DMA YES Serial
Interface
Remarks -
DMA
Remarks DMAC x 2 ch LCD
Segment
Count 0
External
Bus
Expansion NO LCD
Remarks -
External
Interrupt
Pins 13 Display
Function NO
I/O
Ports 58 Display
Function
Remarks -
8-bit
Timer (ch) 0 Operating
Voltage
Max (V) 5.5
16-bit
Timer (ch) 8 Operating
Voltage
Min (V) 1.6
32-bit
Timer (ch) 0 Power
Supply -
Watchdog
Timer (ch) 1 Operating
Temperature
Max (°C) 85
Other
Timers Interval Timer x 1 ch Operating
Temperature
Min (°C) -40
PWM
Output 7 Operating
Temperature
Remarks Ambient Temperature
3-phase
PWM
Output
Function NO Remarks -
8-bit
A/D
Converter (ch) 0 Production
Status Mass Production
10-bit
A/D
Converter (ch) 12
1、芯片:R5F100LEAFB
Price - 12-bit
A/D
Converter (ch) 0
Bit Size 16 Over
14-bit
A/D
Converter (ch) 0
A/D
Converter NO
D/A
Converter (ch) 0
D/A
Converter (ch) 0
Program
D/A
Converter (ch) 0
RAM
(KB) 4 Over
14-bit
D/A
Converter (ch) 0
Program
Memory
Cache
Memory NO Ethernet
Remarks -
Cache
Memory
Remarks - USB
Host NO
Pin Count 64 USB
Peripheral NO
CPU RL78 USB
Ports (ch) 0
Hi-Speed
Support NO
Sub-clock
Endpoints 0
On-chip
Oscillator YES USB
Isochronous
Transfer
Support NO
On-chip
Oscillator
Remarks -
PLL NO Clocked
Serial
Interface (ch) 6
RTC YES SPI (ch) 0
Memory
Management
Unit NO LIN (ch) 7
DMA YES Serial
Interface
Remarks -
DMA
Segment
Count 0
External
Bus
Expansion NO LCD
Remarks -
External
Interrupt
Pins 13 Display
Function NO
I/O
Ports 58 Display
Function
Remarks -
8-bit
Voltage
Max (V) 5.5
16-bit
Voltage
Min (V) 1.6
32-bit
Timer (ch) 0 Power
Supply -
Watchdog
Temperature
Max (°C) 85
Other
Temperature
Min (°C) -40
PWM
Output 7 Operating
Temperature
3-phase
PWM
Output
8-bit
A/D
10-bit
A/D
Converter (ch) 12
- | 12-bit0 |
16 | Over0 |
RL78 | Delta-SigmaNO |
RL78/G1x | 8-bit0 |
RL78/G13 | 10-bit0 |
64 | 12-bit0 |
4 | Over0 |
4 | CAN (ch)0 |
Flash memory | EthernetNO |
NO | Ethernet- |
- | USBNO |
64 | USBNO |
RL78 | USB0 |
32 | USBNO |
YES | USB0 |
YES | USBNO |
32M, 24M, 16M, 12M, 8M, 4M, 1M Low-speed Oscillator 15kHz | USB- |
NO | Clocked6 |
YES | SPI (ch)0 |
YES | UART (ch)3 |
YES | I2C (ch)1 |
NO | LIN (ch)7 |
NO | IEBus (ch)0 |
YES | Serial- |
DMAC x 2 ch | LCD0 |
NO | LCD- |
13 | DisplayNO |
58 | Display- |
0 | Operating5.5 |
8 | Operating1.6 |
0 | Power- |
1 | Operating85 |
Interval Timer x 1 ch | Operating-40 |
7 | OperatingAmbient Temperature |
NO | Remarks- |
0 | ProductionMass Production |
12 |
- | 12-bit0 |
16 | Over0 |
RL78/G1x | 8-bit0 |
64 | 12-bit0 |
4 | Over0 |
4 | CAN (ch)0 |
NO | Ethernet- |
- | USBNO |
64 | USBNO |
RL78 | USB0 |
32 | USBNO |
YES | USB0 |
YES | USBNO |
NO | Clocked6 |
YES | SPI (ch)0 |
YES | UART (ch)3 |
YES | I2C (ch)1 |
NO | LIN (ch)7 |
NO | IEBus (ch)0 |
YES | Serial- |
NO | LCD- |
13 | DisplayNO |
58 | Display- |
0 | Operating5.5 |
8 | Operating1.6 |
0 | Power- |
1 | Operating85 |
NO | Remarks- |
12 |
- | 12-bit0 |
16 | Over0 |
RL78/G1x | 8-bit0 |
64 | 12-bit0 |
4 | Over0 |
4 | CAN (ch)0 |
NO | Ethernet- |
- | USBNO |
64 | USBNO |
RL78 | USB0 |
32 | USBNO |
YES | USB0 |
YES | USBNO |
NO | Clocked6 |
YES | SPI (ch)0 |
YES | UART (ch)3 |
YES | I2C (ch)1 |
NO | LIN (ch)7 |
NO | IEBus (ch)0 |
YES | Serial- |
NO | LCD- |
13 | DisplayNO |
58 | Display- |
0 | Operating5.5 |
8 | Operating1.6 |
0 | Power- |
1 | Operating85 |
NO | Remarks- |
12 |
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 | |
汽车电子中巡航控制系统的使用被打赏10分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏100分 | |
分享汽车电子中巡航控制系统知识被打赏10分 |
