电子产品世界 » 论坛首页 » 企业专区 » Renesas » 瑞萨RL78/G13开发板验证笔记
共37条 1/4 1 2 3 4 › 跳转至页
瑞萨RL78/G13开发板验证笔记
2012-08-20 20:40:18     打赏
今天接到通知可以送RL78/G13开发板一套,RL78/G13开发板试验开始啦。
关键词: 瑞萨     开发     验证     笔记
2012-08-21 08:48:04     打赏
耐心,板子很快就到
2012-08-23 15:09:24     打赏
RL78/G13开发板资料:
1、芯片:R5F100LEAFB
Price - 12-bit
A/D
Converter (ch) 0
Bit Size 16 Over
14-bit
A/D
Converter (ch) 0
Family RL78 Delta-Sigma
A/D
Converter NO
Series RL78/G1x 8-bit
D/A
Converter (ch) 0
Group RL78/G13 10-bit
D/A
Converter (ch) 0
Program
Memory (KB) 64 12-bit
D/A
Converter (ch) 0
RAM
(KB) 4 Over
14-bit
D/A
Converter (ch) 0
Data Flash (KB) 4 CAN (ch) 0
Program
Memory
Type Flash memory Ethernet NO
Cache
Memory NO Ethernet
Remarks -
Cache
Memory
Remarks - USB
Host NO
Pin Count 64 USB
Peripheral NO
CPU RL78 USB
Ports (ch) 0
Max. Freq (MHz) 32 USB
Hi-Speed
Support NO
Sub-clock
(32.768 kHz) YES USB
Endpoints 0
On-chip
Oscillator YES USB
Isochronous
Transfer
Support NO
On-chip
Oscillator
Freq. (MHz) 32M, 24M, 16M, 12M, 8M, 4M, 1M Low-speed Oscillator 15kHz USB
Remarks -
PLL NO Clocked
Serial
Interface (ch) 6
RTC YES SPI (ch) 0
Power-On Reset YES UART (ch) 3
Low Voltage Detection YES I2C (ch) 1
Memory
Management
Unit NO LIN (ch) 7
Floating Point Unit NO IEBus (ch) 0
DMA YES Serial
Interface
Remarks -
DMA
Remarks DMAC x 2 ch LCD
Segment
Count 0
External
Bus
Expansion NO LCD
Remarks -
External
Interrupt
Pins 13 Display
Function NO
I/O
Ports 58 Display
Function
Remarks -
8-bit
Timer (ch) 0 Operating
Voltage
Max (V) 5.5
16-bit
Timer (ch) 8 Operating
Voltage
Min (V) 1.6
32-bit
Timer (ch) 0 Power
Supply -
Watchdog
Timer (ch) 1 Operating
Temperature
Max (°C) 85
Other
Timers Interval Timer x 1 ch Operating
Temperature
Min (°C) -40
PWM
Output 7 Operating
Temperature
Remarks Ambient Temperature
3-phase
PWM
Output
Function NO Remarks -
8-bit
A/D
Converter (ch) 0 Production
Status Mass Production
10-bit
A/D
Converter (ch) 12
Price 12-bit
A/D
Converter (ch) Bit Size Over
14-bit
A/D
Converter (ch) Family Delta-Sigma
A/D
Converter Series 8-bit
D/A
Converter (ch) Group 10-bit
D/A
Converter (ch) Program
Memory (KB) 12-bit
D/A
Converter (ch) RAM
(KB) Over
14-bit
D/A
Converter (ch) Data Flash (KB) CAN (ch) Program
Memory
Type Ethernet Cache
Memory Ethernet
Remarks Cache
Memory
Remarks USB
Host Pin Count USB
Peripheral CPU USB
Ports (ch) Max. Freq (MHz) USB
Hi-Speed
Support Sub-clock
(32.768 kHz) USB
Endpoints On-chip
Oscillator USB
Isochronous
Transfer
Support On-chip
Oscillator
Freq. (MHz) USB
Remarks PLL Clocked
Serial
Interface (ch) RTC SPI (ch) Power-On Reset UART (ch) Low Voltage Detection I2C (ch) Memory
Management
Unit LIN (ch) Floating Point Unit IEBus (ch) DMA Serial
Interface
Remarks DMA
Remarks LCD
Segment
Count External
Bus
Expansion LCD
Remarks External
Interrupt
Pins Display
Function I/O
Ports Display
Function
Remarks 8-bit
Timer (ch) Operating
Voltage
Max (V) 16-bit
Voltage
Min (V) 32-bit
Timer (ch) Power
Supply Watchdog
Temperature
Max (°C) Other
Timers Operating
Temperature
Min (°C) PWM
Output Operating
Temperature
Remarks 3-phase
PWM
Output
Function Remarks 8-bit
A/D
Converter (ch) Production
Status 10-bit
A/D
Converter (ch)
-0
160
RL78NO
RL78/G1x0
RL78/G130
640
40
40
Flash memoryNO
NO-
-NO
64NO
RL780
32NO
YES0
YESNO
32M, 24M, 16M, 12M, 8M, 4M, 1M Low-speed Oscillator 15kHz-
NO6
YES0
YES3
YES1
NO7
NO0
YES-
DMAC x 2 ch0
NO-
13NO
58-
05.5
81.6
0-
185
Interval Timer x 1 ch-40
7Ambient Temperature
NO-
0Mass Production
12
Price 12-bit
A/D
14-bit
A/D
A/D
D/A
D/A
Memory (KB) 12-bit
D/A
Converter (ch) RAM
(KB) Over
14-bit
D/A
Memory
Type Ethernet Cache
Memory Ethernet
Remarks Cache
Memory
Remarks USB
Host Pin Count USB
Peripheral CPU USB
Hi-Speed
Support Sub-clock
(32.768 kHz) USB
Endpoints On-chip
Oscillator USB
Isochronous
Transfer
Support On-chip
Oscillator
Freq. (MHz) USB
Remarks PLL Clocked
Serial
Management
Interface
Remarks DMA
Remarks LCD
Segment
Count External
Bus
Expansion LCD
Remarks External
Interrupt
Pins Display
Function I/O
Ports Display
Function
Remarks 8-bit
Voltage
Max (V) 16-bit
Voltage
Min (V) 32-bit
Timer (ch) Power
Supply Watchdog
Temperature
Max (°C) Other
Timers Operating
Temperature
Min (°C) PWM
Output Operating
Temperature
Remarks 3-phase
PWM
Output
A/D
Status 10-bit
A/D
Converter (ch)
-0
160
RL78NO
RL78/G1x0
RL78/G130
640
40
40
Flash memoryNO
NO-
-NO
64NO
RL780
32NO
YES0
YESNO
NO6
YES0
YES3
YES1
NO7
NO0
YES-
DMAC x 2 ch0
NO-
13NO
58-
05.5
81.6
0-
185
NO-
0Mass Production
12
Price 12-bit
A/D
14-bit
A/D
A/D
D/A
D/A
Memory (KB) 12-bit
D/A
Converter (ch) RAM
(KB) Over
14-bit
D/A
Memory
Type Ethernet Cache
Memory Ethernet
Remarks Cache
Memory
Remarks USB
Host Pin Count USB
Peripheral CPU USB
Hi-Speed
Support Sub-clock
(32.768 kHz) USB
Endpoints On-chip
Oscillator USB
Isochronous
Transfer
Support On-chip
Oscillator
Freq. (MHz) USB
Remarks PLL Clocked
Serial
Management
Interface
Remarks DMA
Remarks LCD
Segment
Count External
Bus
Expansion LCD
Remarks External
Interrupt
Pins Display
Function I/O
Ports Display
Function
Remarks 8-bit
Voltage
Max (V) 16-bit
Voltage
Min (V) 32-bit
Timer (ch) Power
Supply Watchdog
Temperature
Max (°C) Other
Timers Operating
Temperature
Min (°C) PWM
Output Operating
Temperature
Remarks 3-phase
PWM
Output
A/D
Status 10-bit
A/D
Converter (ch)
-0
160
RL78NO
RL78/G1x0
RL78/G130
640
40
40
Flash memoryNO
NO-
-NO
64NO
RL780
32NO
YES0
YESNO
NO6
YES0
YES3
YES1
NO7
NO0
YES-
DMAC x 2 ch0
NO-
13NO
58-
05.5
81.6
0-
185
NO-
0Mass Production
12
2012-08-25 08:44:34     打赏
网站这几天都上不了,今天可以了。先安装开发环境,那个软件还没搞定。看看图片吧。
2012-08-25 09:01:47     打赏
楼主 ,IAR 软件暂时没有离线XX的方法。
其瑞萨自家的Cube Suite Plus 在无liscence的情况下,可以编译64k以下的文档,这款就可以使用
2012-08-25 10:28:55     打赏
编辑编辑吧,这页面够宽阔
2012-08-25 19:26:06     打赏
这个页面是图片的问题,现在搞定了。现在有个问题是,在安装CubeSuitePlus_Package_V10201.exe的时候,提示:Failed to decompress the archiv  请问是什么问题呢?
2012-08-26 10:48:48     打赏
从英语的字面意思上看,貌似是楼主的文件损坏了。
再重新从光盘里拷出来试试。
我使用IAR, 没有装过cube suite plus
2012-08-26 14:42:21     打赏
那个demo应该不用安装 .net framework的。而其RFP确实需要安装这个
2012-08-26 15:51:27     打赏
暂时先使用OCD模式吧~
那个IAR的使用分享我正在撰写,等那个号恢复后,我会给大家奉上的。
