假如我设置P1 = _01_Pn0_OUTPUT_1 ,我想用这个端口连接外围电路上的一个引脚,通过设置该端口为0和1来控制外围电路上的东西。但是我把P1设置成1可以,但设置成0就老是出错,怎么回事,求教大虾们。
共9条
帮我看看这动态显示怎么老是出错类?
unsigned table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned table1[]={
0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,
0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f};
void delay(unsigned int x)
unsigned int i,j;
for(i=x;i>0;i--)
for(j=2000;j>0;j--);
void display(unsigned char y)
P3_bit.no0=1;
P1=table[y];
P3_bit.no0=0;
P1=0xff;
P2=table1[y];
delay(2000);
void main(void)
/* Start user code. Do not edit comment generated here */
unsigned int w;
while (1U)
for(w=0;w<16;w++)
display(w);
/* End user code. Do not edit comment generated here */
共9条
