电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » FPGA实验连载(一、流水灯实验)
共4条 1/1 1 跳转至页
FPGA实验连载(一、流水灯实验)
2012-10-12 23:19:37     打赏
实验一、流水灯实验!
初学者必学的实验!在此次中为大家书写实验代码,已经经过测试的,可以移植 FPGA,稍微的差别就是建立工程中,得根据开发板的具体管脚而相应的配置!!
--本实验为LED流水灯实验。
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.std_logic_unsigned.ALL;
ENTITY LampsSequencer is
     PORT(
          clk:in STD_LOGIC;
          led1:out STD_LOGIC_VECTOR(7 DOWNTO 0));
END LampsSequencer;
ARCHITECTURE light OF LampsSequencer IS
SIGNAL clk1,CLK2:std_logic;
BEGIN
P1:PROCESS (clk)
VARIABLE count:INTEGER RANGE  0 TO 999999;
BEGIN
    IF clk'EVENT AND clk='1' THEN                            --当时钟脉冲上升沿到来时执行下面语句
       IF count<=499999 THEN
          clk1<='0';                                          --当count<=499999时divls=0并且count加1
          count:=count+1;
        ELSIF count>=499999 AND count<=999999 THEN            --当ount>=499999 并且 count<=999998时
               clk1<='1';                                            --
               count:=count+1;                                --clk1=1并且count加1
        ELSE count:=0;                                        --当count>=499999时清零count1
        END IF;
     END IF;
END PROCESS ;
P3:PROCESS(CLK1)
begin
   IF clk1'event AND clk1='1'THEN
 clk2<=not clk2;
 END IF;
END PROCESS P3;
P2:PROCESS(clk2)
variable count1:INTEGER RANGE 0 TO 16;                         --定义的整型变量用做计数器
BEGIN        --
IF clk2'event AND clk2='1'THEN                                 --当时钟脉冲上升沿到来时执行下面语句
   if count1<=16 then                                          --当COUNT1<=9时执行下面语句
      if count1=15 then                                        --当COUNT1=8时,COUNT1清零
         count1:=0;                                                 --
      end if;                                                            --
      CASE count1 IS                                             --CASE语句给输出LED1赋值
      WHEN 0=>led1<="11111110";                        --依次点亮发光二极管
      WHEN 1=>led1<="11111100";                        --
      WHEN 2=>led1<="11111000";                        --
      WHEN 3=>led1<="11110000";                        --
      WHEN 4=>led1<="11100000";                        --
      WHEN 5=>led1<="11000000";                        --
      WHEN 6=>led1<="10000000";                        --
      WHEN 7=>led1<="00000000";
      WHEN 8=>led1<= "01111111";                        --依次点亮发光二极管
      WHEN 9=>led1<= "00111111";                        --
      WHEN 10=>led1<="00011111";                        --
      WHEN 11=>led1<="00001111";                        --
      WHEN 12=>led1<="00000111";                        --
      WHEN 13=>led1<="00000011";                        --
      WHEN 14=>led1<="00000001";                        --
      WHEN 15=>led1<="00000000";                        --                       --
      WHEN OTHERS=>led1<="11111111";
      END CASE;
      count1:=count1+1;
    end if;
end if;
end process;
END light;
关键词: 实验     连载     流水     count
2012-11-18 21:38:37     打赏
怎么看起来像VHDL啊
2012-11-21 19:05:07     打赏
不错!学习
2012-11-21 23:05:44     打赏
顶顶。。。
共4条 1/1 1 跳转至页
