4.开关控制数码管显示
波动开关,数码管显示相应数字
用case语句实现。
5.数码管模60计数器
为了减少视频时间,把计数改为0.125s记一次,
部分代码如下:
always @(posedge clk or negedge rst_n)
begin
if(!rst_n)
begin
uni<=1'd0;
ten<=1'd0;
end
else
begin
if(de_cnt==26'd6259999)
begin
if(uni==4'd9 && ten<3'd5)
begin
uni<=1'd0;
ten<=ten+1'd1;
end
else if(uni==4'd9 && ten==3'd5)
begin
uni<=1'd0;
ten<=1'd0;
end
else
uni<=uni+1'd1;
end
end
end
always @(dis_dat)
begin
case(dis_dat)
3'b000: sm_bit=8'b11111110;
3'b001: sm_bit=8'b11111101;
default sm_bit=8'b11111111;
endcase
end
always @(sm_bit)
begin
case(sm_bit)
8'b11111110: datout_buf<=uni;
8'b11111101: datout_buf<=ten;
default datout_buf=0;
endcase
end
always @(datout_buf)
begin
case(datout_buf)
4'd0: sm_seg=8'hc0;
4'd1: sm_seg=8'hf9;
4'd2: sm_seg=8'ha4;
4'd3: sm_seg=8'hb0;
4'd4: sm_seg=8'h99;
4'd5: sm_seg=8'h92;
4'd6: sm_seg=8'h82;
4'd7: sm_seg=8'hd8;
4'd8: sm_seg=8'h80;
4'd9: sm_seg=8'h90;
default sm_seg=8'hc0;
endcase
end
endmodule
6.按键控制数码管循环显示0~9
先做了按键没经过消抖的实验,点亮LED时发现灯的状态基本是随机的,数码管显示也是随机的数字,还以为是代码写的有问题,加上消抖后,显示就很正常了,按键的抖动非常厉害。
主要代码:
初始状态:灯亮,数码管显示0
begin
if(!rst_n)
data<=1'd0;
else
if(key_low)
begin
led_out<=~led_out;
if(data==4'd9)
data<=1'd0;
else
data<=data+1'd1;
end
end
always @(data)
begin
case(data)
4'd0: sm_seg=8'hc0;
4'd1: sm_seg=8'hf9;
4'd2: sm_seg=8'ha4;
4'd3: sm_seg=8'hb0;
4'd4: sm_seg=8'h99;
4'd5: sm_seg=8'h92;
4'd6: sm_seg=8'h82;
4'd7: sm_seg=8'hd8;
4'd8: sm_seg=8'h80;
4'd9: sm_seg=8'h90;
endcase
end
assign sm_bit=8'b11111110;
endmodule
主要代码:
初始状态:灯亮,数码管显示0
begin
if(!rst_n)
data<=1'd0;
else
if(key_low)
begin
led_out<=~led_out;
if(data==4'd9)
data<=1'd0;
else
data<=data+1'd1;
end
end
always @(data)
begin
case(data)
4'd0: sm_seg=8'hc0;
4'd1: sm_seg=8'hf9;
4'd2: sm_seg=8'ha4;
4'd3: sm_seg=8'hb0;
4'd4: sm_seg=8'h99;
4'd5: sm_seg=8'h92;
4'd6: sm_seg=8'h82;
4'd7: sm_seg=8'hd8;
4'd8: sm_seg=8'h80;
4'd9: sm_seg=8'h90;
endcase
end
endmodule
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
