module key2(clk,rst_n,key,led);
//programmed by haohaolinux
input clk,rst_n,key;
output led;
reg key_rst;
always @(posedge clk or negedge rst_n)
if(!rst_n)
key_rst=1'b1;
else
key_rst=key;
reg key_rst_r;
if(!rst_n)
key_rst_r=1'b1;
else
key_rst_r=key_rst;
//key_an捕捉key的下降沿,当有按键按下时,key_an置高
wire key_an=key_rst_r & (~key_rst);
//计数,当有按键按下时,从0开始计数。。
reg [19:0] cnt;
always@(posedge clk or negedge rst_n)
if(!rst_n)
cnt=20'b0;
else if(key_an)
cnt=20'b0;
else
cnt=cnt+1;
//当计数器满的时候,再次捕捉按键是否被按下,如果被按下,则led_ctrl置高。。
reg low_sw;
if(!rst_n)
low_sw=1'b1;
else if(cnt==20'hfffff)
low_sw=key;
reg low_sw_r;
if(!rst_n)
low_sw_r=1'b1;
else
low_sw_r=low_sw;
//捕捉low sw的下降沿
wire led_ctrl=low_sw_r & (~low_sw);
reg d1;
if(!rst_n)
d1=0;
else
if(led_ctrl) d1=~d1;
assign led=d1?1:0; endmodule
module switch(switch,LED);
input switch;
output LED;
assign LED=switch?1:0; endmodule
module digitron(clk,rst_n,sm_cs,sm_db);
input clk,rst_n;
output [7:0] sm_cs;
output [6:0] sm_db;
//计数,2^24=16*10^6;即16*10^6*20ns=0.32s=320ms
reg [24:0] cnt;
if(!rst_n) cnt<=25'b0;
else cnt<=cnt+1'b1;
reg [3:0] num;
if(!rst_n) num<=4'b0;
else if(cnt==25'h1ff_ffff) num<=num+1'b1;
parameter
seg0 = 7'hc0,
seg1 = 7'hf9,
seg2 = 7'ha4,
seg3 = 7'hb0,
seg4 = 7'h99,
seg5 = 7'h92,
seg6 = 7'h82,
seg7 = 7'hf8,
seg8 = 7'h80,
seg9 = 7'h90,
sega = 7'h88,
segb = 7'h83,
segc = 7'hc6,
segd = 7'ha1,
sege = 7'h86,
segf = 7'h8e;
//segf =7'hff;
reg [6:0] sm_dbr;
always @(num)
case(num)
4'h0:sm_dbr<=seg0;
4'h1:sm_dbr<=seg1;
4'h2:sm_dbr<=seg2;
4'h3:sm_dbr<=seg3;
4'h4:sm_dbr<=seg4;
4'h5:sm_dbr<=seg5;
4'h6:sm_dbr<=seg6;
4'h7:sm_dbr<=seg7;
4'h8:sm_dbr<=seg8;
4'h9:sm_dbr<=seg9;
4'hA:sm_dbr<=sega;
4'hB:sm_dbr<=segb;
4'hC:sm_dbr<=segc;
4'hD:sm_dbr<=segd;
4'hE:sm_dbr<=sege;
4'hF:sm_dbr<=segf;
default:;
endcase
assign sm_db = sm_dbr;
assign sm_cs = 8'h00;
endmodule
动态数码管程序:
module digitron2(clk,rst_n,sm_cs,sm_db);
input clk,rst_n;
output [3:0] sm_cs;
output [6:0] sm_db;
reg [24:0] cnt;
else cnt<=cnt+1'b1;
reg [3:0] shi,ge;
if(!rst_n)
begin
shi = 4'd0;
ge = 4'd0;
end
begin
if(ge == 4'd9)
begin
ge = 4'hf;
shi = shi+1;
end
else
shi = shi;
if(shi == 4'd9)
shi = 0;
else
shi = shi;
ge = ge+1;
end
parameter
seg0 = 7'hc0,
seg1 = 7'hf9,
seg2 = 7'ha4,
seg3 = 7'hb0,
seg4 = 7'h99,
seg5 = 7'h92,
seg6 = 7'h82,
seg7 = 7'hf8,
seg8 = 7'h80,
seg9 = 7'h90;
reg [3:0] num;
reg [6:0] sm_dbr;
always @(num)
case(num)
4'h0:sm_dbr<=seg0;
4'h1:sm_dbr<=seg1;
4'h2:sm_dbr<=seg2;
4'h3:sm_dbr<=seg3;
4'h4:sm_dbr<=seg4;
4'h5:sm_dbr<=seg5;
4'h6:sm_dbr<=seg6;
4'h7:sm_dbr<=seg7;
4'h8:sm_dbr<=seg8;
4'h9:sm_dbr<=seg9;
default:;
endcase
reg sm_cs2_r,sm_cs1_r;
always @(clk or shi or ge)
begin
if(cnt[20])
begin
sm_cs2_r = 0;
sm_cs1_r = 1;
num = shi;
end
else
begin
sm_cs2_r = 1;
sm_cs1_r = 0;
num = ge;
end
end
assign sm_cs[1:0] = 2'b11;
assign sm_cs[3] = sm_cs1_r;
assign sm_cs[2] = sm_cs2_r;
endmodule
蜂鸣器程序:
module beep(clk,rst_n,beep);
input clk,rst_n;
output beep;
reg [24:0] cnt;
reg beep;
else cnt<=cnt+1'b1;
if(!rst_n) beep<=1'b0;
else if(cnt[18])
beep <= 1'b1;
else
beep <= 1'b0;
endmodule
| 有奖活动 | |
| 这个春节你犒赏自己什么了?分享你的故事,有奖征集 | |
| 2026年“我要开发板活动”第三季,开始了! | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| OK1126B-S开发板下函数构建及步进电机驱动控制被打赏¥25元 | |
| 【S32K3XX】LPI2C 参数配置说明被打赏¥20元 | |
| OK1126B-S开发板的脚本编程及应用设计被打赏¥27元 | |
| 5v升压8.4v两节锂电池充电芯片,针对同步和异步的IC测试被打赏¥35元 | |
| 【S32K3XX】S32DS LPI2C 配置失败问题解决被打赏¥22元 | |
| 【S32K3XX】FLASH 的 DID 保护机制被打赏¥19元 | |
| OK1126B-S开发板串口通信及其使用被打赏¥18元 | |
| 【S32K3XX】多核 CORE ID 获取被打赏¥18元 | |
| OK1126B-S开发板的GPIO资源及其使用被打赏¥20元 | |
| 【分享开发笔记,赚取电动螺丝刀】三分钟快速上手驱动屏幕(Arduino IDE环境)被打赏¥23元 | |
