外部中断函数
· attachInterrupt(interrupt, , mode) 外部中断只能用到数字IO口2和3,interrupt表示中断口初始0或1,表示一个功能函数,mode:LOW低电平中断,CHANGE有变化就中断,RISING上升沿中断,FALLING下降沿中断。
· detachInterrupt(interrupt) 中断开关,interrupt=1 开,interrupt=0 关。
中断使能函数
· interrupts() 使能中断
· noInterrupts() 禁止中断
串口收发函数
· Serial.begin(speed) 串口定义波特率函数,speed表示波特率,如9600,19200等。
· int Serial.available() 判断缓冲器状态。
· int Serial.read() 读串口并返回收到参数。
· Serial.flush() 清空缓冲器。
· Serial.print(data) 串口输出数据。
· Serial.println(data) 串口输出数据并带回车符。
官方库文件
· EEPROM - EEPROM读写程序库
· Ethernet - 以太网控制器程序库
· LiquidCrystal - LCD控制程序库
· Servo - 舵机控制程序库
· SoftwareSerial - 任何数字IO口模拟串口程序库
· Stepper - 步进电机控制程序库
· Wire - TWI/I2C总线程序库
· Matrix - LED矩阵控制程序库
· Sprite - LED矩阵图象处理控制程序库
非官方库文件
· DateTime - a library for keeping track of the current date and time in software.
· Debounce - for reading noisy digital inputs (e.g. from buttons)
· Firmata - for communicating with applications on the computer using a standard serial protocol.
· GLCD - graphics routines for LCD based on the KS0108 or equivalent chipset.
· LCD - control LCDs (using 8 data lines)
· LCD 4 Bit - control LCDs (using 4 data lines)
· LedControl - for controlling LED matrices or seven-segment displays with a MAX7221 or MAX7219.
· LedControl - an alternative to the Matrix library for driving multiple LEDs with Maxim chips.
· Messenger - for processing text-based messages from the computer
· Metro - help you time actions at regular intervals
· MsTimer2 - uses the timer 2 interrupt to trigger an action every N milliseconds.
· OneWire - control devices (from Dallas Semiconductor) that use the One Wire protocol.
· PS2Keyboard - read characters from a PS2 keyboard.
· Servo - provides software support for Servo motors on any pins.
· Servotimer1 - provides hardware support for Servo motors on pins 9 and 10
· Simple Message System - send messages between Arduino and the computer
· SSerial2Mobile - send text messages or emails using a cell phone (via AT commands over software serial)
· TextString - handle strings
· TLC5940 - 16 channel 12 bit PWM controller.
· X10 - Sending X10 signals over AC power lines
板子刚到之后,仔细的看了一下,做的非常精细,甚是喜爱
下面讲解一下怎么玩拿到一个没用过的板子,我还是像玩51单片机一样,想先知道程序是怎么下载的,在论坛里逛了逛,看了一下其他人的帖子,知道是用mini-USB连接的,正好自己的Mp4就是这种,连接之后,板子上的4个 blue LEDs 开始闪烁,这是要把SW3搬到RUN的一端,在按一下SW1(复位)的按钮,这是就启动驱动的安装,我的电脑是自动就安装好了,我也没做什么。然后在计算机就出来这个……
看到了空间的大小464KB,这就是存放代码的地方,我似乎开始理解了为什么叫做开源代码(个人理解,希望懂得人指正),然后4个Blue LEDs不闪了,但是一直亮着
此时表明你的驱动已经安装成功了,
,就可以开始你后面的实验了
当然我驱动的安装成功还是看到了,板盒上的网址:http://sakuraboard.net 点进去之后,就有官网的详细教程,给个图大家看一下
。下面讲解一下怎么玩拿到一个没用过的板子,我还是像玩51单片机一样,想先知道程序是怎么下载的,在论坛里逛了逛,看了一下其他人的帖子,知道是用mini-USB连接的,正好自己的Mp4就是这种,连接之后,板子上的4个 blue LEDs 开始闪烁,这是要把SW3搬到RUN的一端,在按一下SW1(复位)的按钮,这是就启动驱动的安装,我的电脑是自动就安装好了,我也没做什么。然后在计算机就出来这个……
此时表明你的驱动已经安装成功了,
,就可以开始你后面的实验了当然我驱动的安装成功还是看到了,板盒上的网址:http://sakuraboard.net 点进去之后,就有官网的详细教程,给个图大家看一下
| 有奖活动 | |
| 2026年“我要开发板活动”第三季,开始了! | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| PTC与NTC功能常规对比被打赏¥14元 | |
| 【分享开发笔记,赚取电动螺丝刀】关于3pin锂电池接口的介绍/使用被打赏¥16元 | |
| 以启明云端ESP32P4开发板实现TF卡读写功能被打赏¥28元 | |
| 【分享开发笔记,赚取电动螺丝刀】树莓派5串口UART0配置被打赏¥25元 | |
| 【STM32F103ZET6】17:分享在Rtos项目中断管理的使用经验被打赏¥23元 | |
| 【STM32F103ZET6】16:分享在中断中恢复串口任务,遇到的问题被打赏¥31元 | |
| 在FireBeetle2ESP32-C5上实现温度大气压检测及显示被打赏¥21元 | |
| 【分享开发笔记,赚取电动螺丝刀】SAME51双串口收发配置被打赏¥27元 | |
| Chaos-nano操作系统在手持式VOC检测设备上的应用被打赏¥37元 | |
| 【分享开发笔记,赚取电动螺丝刀】关于在导入第三方库lib时,wchart类型冲突的原因及解决方案被打赏¥30元 | |
