电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » whywhy89713的进程贴
共17条 2/2 ‹ 1 2 跳转至页
2013-03-18 21:00:59     打赏
11楼
这一堆代码~~~~
2013-03-18 21:01:31     打赏
12楼
3-3按键除抖
module key(CLK,RESET,KEY,LED);
input CLK;
input RESET;
input KEY;
output LED;
reg LED;
reg [19:0] delay_cnt;
wire kscan;
wire klow;
reg ksamp;
reg ksampr;
reg krst;
reg krstr;
//edge detect
always@(posedge CLK or negedge RESET)
 begin
  if(!RESET)
   ksamp<=1'b1;
  else
   ksamp<=KEY;
 end
 begin
  if(!RESET)
   ksampr<=1'b1;
  else
   ksampr<=ksamp;
 end
assign kscan=ksampr&(~ksamp);
//delay 20ms
 begin
  if(!RESET)
   delay_cnt<=20'h0;
  else if(kscan)
   delay_cnt<=20'h0;
  else
   delay_cnt<=delay_cnt+1'b1;
 end
 begin
  if(!RESET)
   krst<=1'b1;
  else if(delay_cnt==20'hfffff)
   krst<=KEY;
 end
 begin
  if(!RESET)
   krstr<=1'b1;
  else
   krstr<=krst;
 end
assign klow=krstr&(~krst);
 begin
  if(!RESET)
   LED<=1'b1;
  else if(klow)
   LED<=~LED;
  else
   LED<=LED;
 end
endmodule
http://player.youku.com/player.php/sid/XNTI4MjYwNzAw/v.swf
3-4 按键除抖+数码管
module key(CLK,RESET,KEY,SEG,DIG);
input CLK;
input RESET;
input KEY;
output [7:0] SEG;
output [7:0] DIG;
reg LED;
wire kscan;
wire klow;
reg ksamp;
reg ksampr;
reg krst;
reg krstr;
reg [7:0] SEG;
wire [7:0] DIG;
reg [3:0] dat;
//edge detect
 begin
  if(!RESET)
   ksamp<=1'b1;
  else
   ksamp<=KEY;
 end
 begin
  if(!RESET)
   ksampr<=1'b1;
  else
   ksampr<=ksamp;
 end
//delay 20ms
 begin
  if(!RESET)
   delay_cnt<=20'h0;
  else if(kscan)
   delay_cnt<=20'h0;
  else
 end
 begin
  if(!RESET)
   krst<=1'b1;
   krst<=KEY;
 end
 begin
  if(!RESET)
   krstr<=1'b1;
  else
   krstr<=krst;
 end
 begin
  if(!RESET)
   dat<=1'b1;
  else if(klow)
   dat<=dat+1'b1;
  else
   dat<=dat;
 end
always@(dat)
 begin
  case(dat)
   4'h0: SEG = 8'hc0;
   4'h1: SEG = 8'hf9;
   4'h2: SEG = 8'ha4;
   4'h3: SEG = 8'hb0;
   4'h4: SEG = 8'h99;
   4'h5: SEG = 8'h92;
   4'h6: SEG = 8'h82;
   4'h7: SEG = 8'hf8;
   4'h8: SEG = 8'h80;
   4'h9: SEG = 8'h90;
   4'ha: SEG = 8'h88;
   4'hb: SEG = 8'h83;
   4'hc: SEG = 8'hc6;
   4'hd: SEG = 8'ha1;
   4'he: SEG = 8'h86;
   4'hf: SEG = 8'h8e;
   endcase
 end
 assign DIG=8'b11111110;
endmodule
http://player.youku.com/player.php/sid/XNTI4MjY1NDY0/v.swf
2013-03-18 21:03:22     打赏
13楼
视频怎么发呀,我超级链接后没有视频的窗口,看了半天也没搞懂
2013-03-18 21:06:58     打赏
14楼
4.蜂鸣器
教程蜂鸣器例题1
module fmq(CLK,RESET,BEEP);
// I/O
input CLK;
input RESET;
output BEEP;
reg BEEP;
reg [24:0] div;
reg [14:0] delay_cnt;
wire [14:0] delay_end;
parameter clk_div0=56817;//50000000/2*440-1
parameter clk_div1=28408;//50000000/4*440-1
assign delay_end=div[24]?clk_div0:clk_div1;
蜂鸣器作业一
变化不大
// I/O
input CLK;
input RESET;
output BEEP;
reg BEEP;
reg [24:0] div;
parameter clk_div0=28408;//50000000/4*440-1
parameter clk_div1=14204;//50000000/8*440-1
//div
 begin
  if(!RESET)
   div<=25'd0;//???25??????0
  else
   div<=div+1'b1;
 end
 begin
  if(!RESET)
   delay_cnt<=delay_end;
  else if(delay_cnt==15'd0)
   begin
    BEEP<=~BEEP;
   end
  else
    delay_cnt<=delay_cnt-1'b1;
   end
 endmodule
2013-03-18 21:08:42     打赏
15楼
蜂鸣器例题2
一个按键对应一个音,中音区需要按着第八个键不放,再继续
module fmq(CLK,RESET,KEY,BEEP);
// I/O
input CLK;
input RESET;
input [7:0] KEY;
output BEEP;
reg BEEP;
reg [15:0] delay_cnt;
reg [15:0] delay_end;
//delay
 begin
  if(!RESET)
   delay_cnt<=16'd0;//???25??????0
  else if((delay_cnt==delay_end)&(!(delay_end==16'hffff)))
   begin
    delay_cnt<=16'd0;
    BEEP=~BEEP;
   end
  else
  delay_cnt=delay_cnt+1'b1;
 end
always@(KEY)
 begin
   case(KEY)
    8'b11111110:delay_end=16'd47774;//m1
    8'b11111101:delay_end=16'd42568;//m2
    8'b11111011:delay_end=16'd37919;//m3
    8'b11110111:delay_end=16'd35791;//m4
    8'b11101111:delay_end=16'd31888;//m5
    8'b11011111:delay_end=16'd28409;//m6
    8'b10111111:delay_end=16'd25309;//m7
    8'b01111110:delay_end=16'd23912;//h1
    8'b01111101:delay_end=16'd21282;//h2
    8'b01111011:delay_end=16'd18961;//h3
    8'b01110111:delay_end=16'd17897;//h4
    8'b01101111:delay_end=16'd15944;//h5
    8'b01011111:delay_end=16'd14205;//h6
    8'b00111111:delay_end=16'd12655;//h7
    default:delay_end=16'd0;
   endcase
 end
 endmodule
2013-03-18 21:13:12     打赏
16楼
电子琴
结婚进行曲
蜂鸣器作业2.zip
2013-03-18 21:28:09     打赏
17楼
LCD显示
1602完全是在Anmko大神的代码上做的
实在惭愧,感谢Anmko大神,写得很清楚
共17条 2/2 ‹ 1 2 跳转至页
