2楼按键篇,
	  今天晚上闲暇时间根据51FPGA的按键部分的教程写的一个简单的按键控制数码管循环显示的程序。
	验证码为啥总是错误
	module Key_Smg(
   input clk,rst_n,
 input Keyin,
 output smgen,
 output [7:0] KeyData
 assign  smgen = 0;
 wire Key_S;
 reg Key_D;
 wire Key_down;
 always @(posedge clk or negedge rst_n)
   if(!rst_n)
  begin
    Key_D <= 1'b1;
  end
 else
   Key_D <= Keyin;
 reg Key_D_t;
   if(!rst_n)
  begin
    Key_D_t <= 1'b1;
  end
 else
   Key_D_t <= Key_D;
 assign Key_S = Key_D_t && (~Key_D);
 reg [3:0] Smgbit;
  if(!rst_n)
    begin
    Smgbit <= 4'd0;
  end
   else if(Key_down)
    if(Smgbit == 4'd9)
    Smgbit <= 4'd0;
   else
      Smgbit <= Smgbit + 1'b1;
 else
     Smgbit  <= Smgbit;
reg [15:0] delay_r;
reg [4:0]  delay_cnt_r;
   if(!rst_n)
   begin
      delay_r <= 16'd0;
   end
 else if(Key_S)
   delay_r <= 16'd0;
 else if(delay_r == 16'hC350)
   delay_r <= 16'd0;
   else
    delay_r <= delay_r + 1'b1;
   if(!rst_n)
   begin
    delay_cnt_r <= 5'd0;
   end
 else
   if(Key_S || (delay_cnt_r == 5'd20)) delay_cnt_r <= 5'd0;
   else
      delay_cnt_r <= delay_cnt_r + 1'b1;
    else
      delay_r <= delay_r;
	reg Key_D2;
  if(!rst_n)
   Key_D2 <= 1'b1;
  else if(delay_cnt_r == 5'd20)
     Key_D2 <= Keyin;
	reg Key_D2_t;
  if(!rst_n)
       Key_D2_t <= 1'b1;
  else
     Key_D2_t <= Key_D2;
assign   Key_down  = Key_D2_t && (~Key_D2);
reg [7:0] timedata_r;
assign KeyData = timedata_r;
  if(!rst_n)
    begin
     timedata_r  <=  8'hff;
    end
  else
    case(Smgbit)
     4'b0000 :  timedata_r <= 8'hC0;                   //0
   4'b0001 :  timedata_r  <= 8'hF9;                   //1
   4'b0010 :  timedata_r  <= 8'hA4;                   //2
   4'b0011 :  timedata_r   <= 8'hB0;                   //3
   4'b0100 :  timedata_r  <= 8'h99;                    //4
   4'b0101 :  timedata_r  <= 8'h92;                     //5
   4'b0110 :  timedata_r  <= 8'h82;                     //6
   4'b0111 :  timedata_r   <= 8'hF8;                    //7
   4'b1000 :  timedata_r  <= 8'h80;                    //8
   4'b1001 :  timedata_r <=  8'h90;                      //9
   4'b1010 :  timedata_r <=  8'hBF;                     //-
   default   : timedata_r  <=  8'hff;
 endcase
endmodule
