共6条
jpeg压缩时用到的8*8的fdct代码
下面是离散余弦变换代码,是jpeg压缩时用到的8*8的fdct代码,是从一个网站上找到的,可是我看不懂:(书上的余弦变换都是用cos表示出来的,而且是二维的,这里却用行列各一次余弦变换,哪位数字信号处理高手给分析一下吧,谢谢!
void fdct_and_quantization(SBYTE *data,SWORD *outdata)
float tmp0, tmp1, tmp2, tmp3, tmp4, tmp5, tmp6, tmp7;
float tmp10, tmp11, tmp12, tmp13;
float z1, z2, z3, z4, z5, z11, z13;
float *dataptr;
float datafloat[64];
float temp;
SBYTE ctr;
BYTE i;
for (i=0;i<64;i++) datafloat[i]=data[i];
/* Pass 1: process rows. */
dataptr=datafloat;
for (ctr = 7; ctr >= 0; ctr--) {
tmp0 = dataptr[0] + dataptr[7];
tmp7 = dataptr[0] - dataptr[7];
tmp1 = dataptr[1] + dataptr[6];
tmp6 = dataptr[1] - dataptr[6];
tmp2 = dataptr[2] + dataptr[5];
tmp5 = dataptr[2] - dataptr[5];
tmp3 = dataptr[3] + dataptr[4];
tmp4 = dataptr[3] - dataptr[4];
/* Even part */
tmp10 = tmp0 + tmp3; /* phase 2 */
tmp13 = tmp0 - tmp3;
tmp11 = tmp1 + tmp2;
tmp12 = tmp1 - tmp2;
dataptr[0] = tmp10 + tmp11; /* phase 3 */
dataptr[4] = tmp10 - tmp11;
z1 = (tmp12 + tmp13) * ((float) 0.707106781); /* c4 */
dataptr[2] = tmp13 + z1; /* phase 5 */
dataptr[6] = tmp13 - z1;
/* Odd part */
tmp10 = tmp4 + tmp5; /* phase 2 */
tmp11 = tmp5 + tmp6;
tmp12 = tmp6 + tmp7;
/* The rotator is modified from fig 4-8 to avoid extra negations. */
z5 = (tmp10 - tmp12) * ((float) 0.382683433); /* c6 */
z2 = ((float) 0.541196100) * tmp10 + z5; /* c2-c6 */
z4 = ((float) 1.306562965) * tmp12 + z5; /* c2+c6 */
z3 = tmp11 * ((float) 0.707106781); /* c4 */
z11 = tmp7 + z3; /* phase 5 */
z13 = tmp7 - z3;
dataptr[5] = z13 + z2; /* phase 6 */
dataptr[3] = z13 - z2;
dataptr[1] = z11 + z4;
dataptr[7] = z11 - z4;
dataptr += 8; /* advance pointer to next row */
/* Pass 2: process columns. */
dataptr = datafloat;
tmp0 = dataptr[0] + dataptr[56];
tmp7 = dataptr[0] - dataptr[56];
tmp1 = dataptr[8] + dataptr[48];
tmp6 = dataptr[8] - dataptr[48];
tmp2 = dataptr[16] + dataptr[40];
tmp5 = dataptr[16] - dataptr[40];
tmp3 = dataptr[24] + dataptr[32];
tmp4 = dataptr[24] - dataptr[32];
/* Even part */
dataptr[32] = tmp10 - tmp11;
dataptr[16] = tmp13 + z1; /* phase 5 */
dataptr[48] = tmp13 - z1;
/* Odd part */
z13 = tmp7 - z3;
dataptr[40] = z13 + z2; /* phase 6 */
dataptr[24] = z13 - z2;
dataptr[8] = z11 + z4;
dataptr[56] = z11 - z4;
dataptr++; /* advance pointer to next column */
for (i = 0; i < 64; i++) {
outdata[i] = (SWORD) datafloat[i];
关键词: 缩时 用到 代码 float tmp10 tmp1
共6条
