1 download src
sudo apt-get install ant (not neccesary)
install jdk
sudo tar -xvf jdk-7u25-linux-x64.tar.gz (in root directory)
sudo vi /etc/profile
JAVA_HOME=/jre1.7.0_25:/jsd1.7.0_25
PATH=$JAVA_HOME/bin:$PATH CLASSPATH=.:$JAVA_HOME/lib/dt.jar:$JAVA_HOME/lib/tools.jar sourc /etc/profile sudo apt-get install maven sudo apt-get install cmake findbugs (in eclipse-help-eclipse marketplace) protocolbuffer download protobuf-2.5.0.tar make clean ./configure --prefix=/usr/local make make check sudo make install sudo /etc/ld.so.conf.d/libprotobuf.conf /usr/local/lib sudo ldconfig protoc --version (check ) 2 BUILDING.TXT cd hadoop-maven-plugins mvn install cd .. mvn eclipse:eclipse -DskipTestseclipse-file-import-existing projects into workspace building distributions: mvn package -Pdist,native,docs -DskipTests -Dtar
10-25
http://beagleboard.org/Getting%20Started
(http://www.embest-tech.cn/community/thread-3088-1-1.html 中国版)
download usb drive (英文版中可以选择不同驱动)
use google chrome, connect to beaglebone black(http://192.168.7.2)
download putty
host : 192.168.7.2 port : 20 use ssh,open and can use shell,login as :root ,no passward
in putty
date + "%F %T" -s "2013/10/25 19:53:00" 同步时间后,(秒可以不精确)使用https://192.168.7.2 进入个gateone
localhost 22 root 进入shell
http://192.168.7.2:3000 enter iDE
