LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY CNT10 IS
PORT (CLK,RST,EN : IN STD_LOGIC;
CQ : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
COUT : OUT STD_LOGIC );
END CNT10;
ARCHITECTURE behav OF CNT10 IS
BEGIN
PROCESS(CLK, RST, EN)
VARIABLE CQI : STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
IF RST = ‘1’ THEN CQI := (OTHERS =>‘0’) ; --计数器复位 (异步)
ELSIF CLK'EVENT AND CLK='1' THEN --检测时钟上升沿
IF EN = '1' THEN --检测是否允许计数
IF CQI < "1001" THEN CQI := CQI + 1; --允许计数
ELSE CQI := (OTHERS =>'0'); --大于9,计数值清零
END IF;
END IF;
END IF;
IF CQI = "1001" THEN COUT <= '1'; --计数大于9,输出进位信号
ELSE COUT <= '0';
END IF;
CQ <= CQI; --将计数值向端口输出
END PROCESS;
END behav;
| 为遥控小车巧添功能被打赏¥26元 | |
