电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 请教TCP强人,“embryonic connection dropped"
共5条 1/1 1 跳转至页
2004-02-10 22:20:57     打赏
我试图Telnet设备,可总是连接失败。 在设备上使用tcpstatShow,结果如下: -> tcpstatShow
TCP:
0 packet sent
0 data packet (0 byte)
0 data packet (0 byte) retransmitted
0 ack-only packet (0 delayed)
0 URG only packet
0 window probe packet
0 window update packet
0 control packet
3 packets received
0 ack (for 0 byte)
0 duplicate ack
0 ack for unsent data
0 packet (0 byte) received in-sequence
0 completely duplicate packet (0 byte)
0 packet with some dup. data (0 byte duped)
0 out-of-order packet (0 byte)
0 packet (0 byte) of data after window
0 window probe
0 packet received after close
0 discarded for bad checksums
0 discarded for bad header offset field
0 discarded because packet too short
0 connection request
0 connection accept
0 connection established (including accepts)
3 connection closed (including 0 drop)
3 embryonic connection dropped
0 segment updated rtt (of 0 attempt)
0 retransmit timeout
0 connection dropped by rexmit timeout
0 persist timeout
0 keepalive timeout
0 keepalive probe sent
0 connection dropped by keepalive
0 pcb cache lookup failed 请教高手,embryonic connection dropped会在什么情况下发生,首先声明我的系统中没有IPSec。 [align=right][color=#000066][此贴子已经被作者于2004-2-10 14:22:57编辑过][/color][/align]
关键词: 请教     强人     embryonic     connectio
2004-02-11 19:41:00     打赏
这么有水平的问题没人来讨论吗?不过昨天歪打正着解决了,原来mac地址是"4d:xx:xx:xx:xx:xx",后来改成"00:xx:xx:xx:xx:xx"就好了,不知作何解。 [align=right][color=#000066][此贴子已经被作者于2004-2-11 11:42:56编辑过][/color][/align]
2004-02-12 02:25:00     打赏
如此?tcp协议栈应该不管对端的mac地址吧,为何报文一直送到tcp层才丢掉?
2004-02-16 20:27:00     打赏
沉得太快了,还想再看看有没有人知道,没有就算了。
2004-02-17 17:51:00     打赏
佩服的五体投地,大侠精辟的分析我仔细拜读了,确实该是如此。当之无愧的TCP强人啊。[em07] [align=right][color=#000066][此贴子已经被作者于2004-2-17 9:55:43编辑过][/color][/align]
共5条 1/1 1 跳转至页
