电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 拆中国电信商务领航2-1中兴定制机EBG-2100【精华】(二)
2013-08-28 15:09:28     打赏
进入web管理终端,默认无法从无线连接管理,只能走LAN口有线才能进入
web登录界面,复位后,默认用户名/口令是:admin/admin
查看的系统信息,貌似没dd,tt,op显示得全面
[attachment=2398957]
默认的时间服务器居然是openwrt的,看样子这个系统很有可能用了openwrt的源代码
配合3G上网卡,可以收发短信
USB口也有网络共享磁盘的功能
带有PPTP VPN服务器功能
wan口配置,可以双wan
无线配置,默认支持多ssid
接上TTL线,从Consol口得到的启动信息如下,供参考:
复制代码
  1. +Trying boot from system <A>
  2. ...use system <A>
  3. Trying NPE-C...phy for NPE-C found!
  4. success. Using NPE-C with PHY 1.
  5. Ethernet lan: MAC address 00:03:47:df:32:a8
  6. IP: 192.168.3.44/255.255.255.0, Gateway: 192.168.3.1
  7. Default server: 192.168.3.78
  8. M/N: 600100907101311561
  9. S/N: 11014002293E7BD9E
  10. MAC: 00:22:93:E7:BD:9E
  11. RedBoot(tm) bootstrap and debug environment [ROMRAM]
  12. Red Hat certified release, version 2.04 - built 03:04:15, Mar 26 2010
  13. Platform: KIXRP435 Development Platform (IXP43X) BE
  14. Copyright (C) 2000, 2001, 2002, 2003, 2004, 2007 Free Software Foundation, Inc.
  15. RAM: 0x00000000-0x08000000, [0x00082b08-0x07fd1000] available
  16. FLASH: 0x50000000 - 0x50400000, 64 blocks of 0x00010000 bytes each.
  17. == Executing boot script in 1.000 seconds - enter ^C to abort
  18. RedBoot>fis load -b 0x100000 ker1;exec -b 0x00100000 -l 0x00120000 -c "console=t
  19. tyMTD,panic console=ttyS0,115200 root=/dev/mtdblock8 ro rootfstype=yaffs2 init=/
  20. etc/preinit"
  21. Uncompressing Linux.............................................................
  22. .............. done, booting the kernel.
  23. Linux version 2.6.20.3 (doris.wang@build-new) (gcc version 3.4.1 20040714 (TimeS
  24. ys 3.4.1-7)) #2 Fri Mar 26 03:07:10 EDT 2010
  25. CPU: XScale-IXP43x Family [69054041] revision 1 (ARMv5TE), cr=000039ff
  26. Machine: Intel KIXRP435 Reference Platform
  27. Memory policy: ECC disabled, Data cache writeback
  28. CPU0: D VIVT undefined 5 cache
  29. CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
  30. CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
  31. Built 1 zonelists.  Total pages: 32512
  32. Kernel command line: console=ttyMTD,panic console=ttyS0,115200 root=/dev/mtdbloc
  33. k8 ro rootfstype=yaffs2 init=/etc/preinit
  34. PID hash table entries: 512 (order: 9, 2048 bytes)
  35. Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
  36. Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
  37. Memory: 128MB = 128MB total
  38. Memory: 127488KB available (2096K code, 203K data, 88K init)
  39. Mount-cache hash table entries: 512
  40. CPU: Testing write buffer coherency: ok
  41. NET: Registered protocol family 16
  42. IXP4xx: Using 16MiB expansion bus window size
  43. PCI: IXP4xx is host
  44. PCI: IXP4xx Using direct access for memory space
  45. PCI: bus0: Fast back to back transfers enabled
  46. dmabounce: registered device 0000:00:0e.0 on pci bus
  47. SCSI subsystem initialized
  48. usbcore: registered new interface driver usbfs
  49. usbcore: registered new interface driver hub
  50. usbcore: registered new device driver usb
  51. NET: Registered protocol family 2
  52. IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
  53. TCP established hash table entries: 4096 (order: 2, 16384 bytes)
  54. TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
  55. TCP: Hash tables configured (established 4096 bind 2048)
  56. TCP reno registered
  57. ixp4xx GPIO-based infrared receiver initialize
  58. NetWinder Floating Point Emulator V0.97 (double precision)
  59. JFFS2 version 2.2. (C) 2001-2006 Red Hat, Inc.
  60. yaffs Mar 26 2010 03:05:26 Installing.
  61. io scheduler noop registered
  62. io scheduler deadline registered (default)
  63. IXP4xx Watchdog Timer: heartbeat 60 sec
  64. Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
  65. serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
  66. tun: Universal TUN/TAP device driver, 1.6
  67. tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
  68. IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
  69. Amd/Fujitsu Extended Query Table at 0x0040
  70. number of CFI chips: 1
  71. cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
  72. Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x3f0000
  73. 8 RedBoot partitions found on MTD device IXP4XX-Flash.0
  74. Creating 8 MTD partitions on "IXP4XX-Flash.0":
  75. 0x00000000-0x00080000 : "RedBoot"
  76. 0x00080000-0x001a0000 : "ker1"
  77. 0x001a0000-0x002c0000 : "ker2"
  78. 0x002c0000-0x003d0000 : "config"
  79. 0x003d0000-0x003e0000 : "flags"
  80. 0x003e0000-0x003f0000 : "panic"
  81. 0x003f0000-0x003ff000 : "FIS directory"
  82. mtd: partition "FIS directory" doesn't end on an erase block -- force read-only
  83. 0x003ff000-0x00400000 : "RedBoot config"
  84. mtd: partition "RedBoot config" doesn't start on an erase block boundary -- forc
  85. e read-only
  86. NAND device: Manufacturer ID: 0xad, Chip ID: 0xd3 (Hynix NAND 1GiB 3,3V 8-bit)
  87. Scanning device for bad blocks
  88. Bad eraseblock 1816 at 0x1c600000
  89. Creating 4 MTD partitions on "ixp4xx-nand":
  90. 0x00000000-0x08000000 : "root1"
  91. 0x08000000-0x10000000 : "root2"
  92. 0x10000000-0x1ff00000 : "data"
  93. 0x1ff00000-0x40000000 : "backup"
  94. ixp4xx-ehci ixp4xx-ehci.0: IXP4XX EHCI Host Controller
  95. ixp4xx-ehci ixp4xx-ehci.0: new USB bus registered, assigned bus number 1
  96. ixp4xx-ehci ixp4xx-ehci.0: irq 32, io mem 0xcd000100
  97. ixp4xx-ehci ixp4xx-ehci.0: USB 0.0 started, EHCI 1.00, driver 27 July 2006
  98. usb usb1: configuration #1 chosen from 1 choice
  99. hub 1-0:1.0: USB hub found
  100. hub 1-0:1.0: 1 port detected
  101. ixp4xx-ehci ixp4xx-ehci.1: IXP4XX EHCI Host Controller
  102. ixp4xx-ehci ixp4xx-ehci.1: new USB bus registered, assigned bus number 2
  103. ixp4xx-ehci ixp4xx-ehci.1: irq 33, io mem 0xce000100
  104. ixp4xx-ehci ixp4xx-ehci.1: USB 0.0 started, EHCI 1.00, driver 27 July 2006
  105. usb usb2: configuration #1 chosen from 1 choice
  106. hub 2-0:1.0: USB hub found
  107. hub 2-0:1.0: 1 port detected
  108. Initializing USB Mass Storage driver...
  109. usbcore: registered new interface driver usb-storage
  110. USB Mass Storage support registered.
  111. rx8025_init
  112. i2c /dev entries driver
  113. : power-on reset was detected, you may have to readjust the clock
  114. result1[1] 0x3
  115. driver name is rx8025<6>loaded driver for RX-8025 SA/NB on addr 50
  116. NET: Registered protocol family 26
  117. ip_conntrack version 2.4 (8192 buckets, 65536 max) - 308 bytes per conntrack
  118. ip_tables: (C) 2000-2006 Netfilter Core Team
  119. arp_tables: (C) 2002 David S. Miller
  120. TCP westwood registered
  121. NET: Registered protocol family 1
  122. NET: Registered protocol family 17
  123. Bridge firewalling registered
  124. 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
  125. All bugs added by David S. Miller <davem@redhat.com>
  126. XScale DSP coprocessor detected.
  127. drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
  128. Time: OSTS clocksource has been installed.
  129. yaffs: dev is 32505864 name is "mtdblock8"
  130. yaffs: passed flags ""
  131. yaffs: Attempting MTD mount on 31.8, "mtdblock8"
  132. yaffs_read_super: isCheckpointed 0
  133. VFS: Mounted root (yaffs2 filesystem) readonly.
  134. Freeing init memory: 88K
  135. Warning: unable to open an initial console.
  136. - preinit -
  137. - init -
  138. ixp400_eth: Initializing IXP400 NPE Ethernet driver software v. 1.8
  139. ixp400_eth: CPU clock speed (approx) = 532 MHz
  140. ixEthMiiPhyId[21040261] value is 0x141
  141. ixEthMiiPhyId[21040261] value is 0x141
  142. ixEthMiiPhyId[21040261] value is 0x141
  143. ixEthMiiPhyId[21040261] value is 0x141
  144. ixEthMiiPhyId[21040261] value is 0x141
  145. ixEthMiiPhyId[21040261] value is 0x141
  146. ixEthMiiPhyId[21040261] value is 0x141
  147. ixEthMiiPhyId[21040261] value is 0x141
  148. ixEthMiiPhyScan() end numphys= 8
  149. ixp400_eth: eth1 is using NPEC and the PHY at address 0
  150. ixp400_eth: eth2 is using NPEA and the PHY at address 1
  151. ixp400_eth: Use default MAC address 00:02:b3:02:02:02 for port 1
  152. ixp400_eth: Use default MAC address 00:02:b3:03:03:03 for port 2
  153. init started:  BusyBox v1.4.2 (2010-03-26 03:17:59 EDT) multi-call binary
  154. Please press Enter to activate this console. Jan  1 00:00:18 (none) syslog.info
  155. syslogd started: BusyBox v1.4.2
  156. Jan  1 00:00:18 (none) user.notice kernel: klogd started: BusyBox v1.4.2 (2010-0
  157. 3-26 03:17:59 EDT)
  158. Jan  1 00:00:18 (none) user.notice kernel: Linux version 2.6.20.3 (doris.wang@bu
  159. ild-new) (gcc version 3.4.1 20040714 (TimeSys 3.4.1-7)) #2 Fri Mar 26 03:07:10 E
  160. DT 2010
  161. Jan  1 00:00:18 (none) user.warn kernel: CPU: XScale-IXP43x Family [69054041] re
  162. vision 1 (ARMv5TE), cr=000039ff
  163. Jan  1 00:00:18 (none) user.warn kernel: Machine: Intel KIXRP435 Reference Platf
  164. orm
  165. Jan  1 00:00:18 (none) user.warn kernel: Memory policy: ECC disabled, Data cache
  166. writeback
  167. Jan  1 00:00:18 (none) user.debug kernel: On node 0 totalpages: 32768
  168. Jan  1 00:00:18 (none) user.debug kernel:   DMA zone: 128 pages used for memmap
  169. Jan  1 00:00:18 (none) user.debug kernel:   DMA zone: 0 pages reserved
  170. Jan  1 00:00:18 (none) user.debug kernel:   DMA zone: 16256 pages, LIFO batch:3
  171. Jan  1 00:00:18 (none) user.debug kernel:   Normal zone: 128 pages used for memm
  172. ap
  173. Jan  1 00:00:18 (none) user.debug kernel:   Normal zone: 16256 pages, LIFO batch
  174. :3
  175. Jan  1 00:00:18 (none) user.warn kernel: CPU0: D VIVT undefined 5 cache
  176. Jan  1 00:00:18 (none) user.warn kernel: CPU0: I cache: 32768 bytes, associativi
  177. ty 32, 32 byte lines, 32 sets
  178. Jan  1 00:00:18 (none) user.warn kernel: CPU0: D cache: 32768 bytes, associativi
  179. ty 32, 32 byte lines, 32 sets
  180. Jan  1 00:00:18 (none) user.warn kernel: Built 1 zonelists.  Total pages: 32512
  181. Jan  1 00:00:18 (none) user.notice kernel: Kernel command line: console=ttyMTD,p
  182. anic console=ttyS0,115200 root=/dev/mtdblock8 ro rootfstype=yaffs2 init=/etc/pre
  183. init
  184. Jan  1 00:00:18 (none) user.warn kernel: PID hash table entries: 512 (order: 9,
  185. 2048 bytes)
  186. Jan  1 00:00:18 (none) user.warn kernel: Dentry cache hash table entries: 16384
  187. (order: 4, 65536 bytes)
  188. Jan  1 00:00:18 (none) user.warn kernel: Inode-cache hash table entries: 8192 (o
  189. rder: 3, 32768 bytes)
  190. Jan  1 00:00:18 (none) user.info kernel: Memory: 128MB = 128MB total
  191. Jan  1 00:00:18 (none) user.notice kernel: Memory: 127488KB available (2096K cod
  192. e, 203K data, 88K init)
  193. Jan  1 00:00:18 (none) user.debug kernel: Calibrating delay loop... 532.48 BogoM
  194. IPS (lpj=2662400)
  195. Jan  1 00:00:18 (none) user.warn kernel: Mount-cache hash table entries: 512
  196. Jan  1 00:00:18 (none) user.info kernel: CPU: Testing write buffer coherency: ok
  197. Jan  1 00:00:18 (none) user.info kernel: NET: Registered protocol family 16
  198. Jan  1 00:00:18 (none) user.warn kernel: IXP4xx: Using 16MiB expansion bus windo
  199. w size
  200. Jan  1 00:00:18 (none) user.warn kernel: PCI: IXP4xx is host
  201. Jan  1 00:00:18 (none) user.warn kernel: PCI: IXP4xx Using direct access for mem
  202. ory space
  203. Jan  1 00:00:18 (none) user.info kernel: PCI: bus0: Fast back to back transfers
  204. enabled
  205. Jan  1 00:00:18 (none) user.info kernel: dmabounce: registered device 0000:00:0e
  206. .0 on pci bus
  207. Jan  1 00:00:18 (none) user.notice kernel: SCSI subsystem initialized
  208. Jan  1 00:00:18 (none) user.info kernel: usbcore: registered new interface drive
  209. r usbfs
  210. Jan  1 00:00:18 (none) user.info kernel: usbcore: registered new interface drive
  211. r hub
  212. Jan  1 00:00:18 (none) user.info kernel: usbcore: registered new device driver u
  213. sb
  214. Jan  1 00:00:18 (none) user.info kernel: NET: Registered protocol family 2
  215. Jan  1 00:00:18 (none) user.warn kernel: IP roipt_domain loading
  216. ute cache hash table entries: 1024 (order: 0, 4096 bytes)
  217. Jan  1 00:00:18 (none) user.warn kernel: TCP established hash table entries: 409
  218. 6 (order: 2, 16384 bytes)
  219. Jan  1 00:00:18 (none) user.warn kernel: TCP bind hash table entries: 2048 (orde
  220. r: 1, 8192 bytes)
  221. Jan  1 00:00:18 (none) user.info kernel: TCP: Hash tables configured (establishe
  222. d 4096 bind 2048)
  223. Jan  1 00:00:18 (none) user.info kernel: TCP reno registered
  224. Jan  1 00:00:18 (none) user.info kernel: ixp4xx GPIO-based infrared receiver ini
  225. tialize
  226. Jan  1 00:00:18 (none) user.warn kernel: NetWinder Floating Point Emulator V0.97
  227. (double precision)
  228. Jan  1 00:00:18 (none) user.info kernel: JFFS2 version 2.2. (C) 2001-2006 Red Ha
  229. t, Inc.
  230. Jan  1 00:00:18 (none) user.warn kernel: yaffs Mar 26 2010 03:05:26 Installing.
  231. Jan  1 00:00:18 (none) user.info kernel: io scheduler noop registered
  232. Jan  1 00:00:18 (none) user.info kernel: io scheduler deadline registered (defau
  233. lt)
  234. Jan  1 00:00:18 (none) user.warn kernel: IXP4xx Watchdog Timer: heartbeat 60 sec
  235. Jan  1 00:00:18 (none) user.info kernel: Serial: 8250/16550 driver $Revision: 1.
  236. 90 $ 2 ports, Jan  1 00:00:18 (none) user.info kernel: serial8250.0: ttyS0 at MM
  237. IO 0xc8000000 (irq = 15) is a XScale
  238. Jan  1 00:00:18 (none) user.info kernel: tun: Universal Tnetfilter PSD loaded -
  239. Success
  240. UN/TAP device driver, 1.6
  241. Jan  1 00:00:18 (none) user.info kernel: tun: (C) 1999-2004 Max Krasnyansky <max
  242. k@qualcomm.com>
  243. Jan  1 00:00:18 (none) user.info kernel: IXP4XX-Flash.0: Found 1 x16 devices at
  244. 0x0 in 16-bit bank
  245. Jan  1 00:00:18 (none) user.warn kernel:  Amd/Fujitsu Extended Query Table at 0x
  246. 0040
  247. Jan  1 00:00:18 (none) user.notice kernel: number of CFI chips: 1
  248. Jan  1 00:00:18 (none) user.notice kernel: cfi_cmdset_0002: Disabling erase-susp
  249. end-program due to code brokenness.
  250. Jan  1 00:00:18 (none) user.notice kernel: Searching for RedBoot partition table
  251. in IXP4XX-Flash.0 at offset 0x3f0ipt_time loading
  252. 000
  253. Jan  1 00:00:18 (none) user.notice kernel: 8 RedBoot partitions found on MTD dev
  254. ice IXP4XX-Flash.0
  255. Jan  1 00:00:18 (none) user.notice kernel: Creating 8 MTD partitions on "IXP4XX-
  256. Flash.0":
  257. Jan  1 00:00:18 (none) userJan  1 00:00:18 (none) user.notiJan  1 00:00:18 (none
  258. ) user.notiJan  1 00:00:18 (none) user.warnJan  1 00:00:18 (none) user.infoJan
  259. 1 00:00:18 (none) user.infoJan  1 00:00:18 (none) user.infoJan  1 00:00:18 (none
  260. ) user.warnJan  1 00:00:18 (none) user.infoJan  1 00:00:18 (none) user.infoJan
  261. 1 00:00:18 (none) user.warnJan  1 00:00:18 (none) user.warnJan  1 00:00:18 (none
  262. ) user.warnJan  1 00:00:18 (none) user.warn kernel: ipt_domain loading
  263. Jan  1 00:00:19 (none) user.warn kernel: netfilter PSD loaded - Success
  264. Jan  1 00:00:19 (none) user.warn kernel: ipt_time loading
  265. netem: version 1.2
  266. Jan  1 00:00:19 (none) user.info kernel: netem: version 1.2
  267. u32 classifier
  268.     Performance counters on
  269.     input device check on
  270.     Actions configured
  271. Jan  1 00:00:19 (none) user.warn kernel: u32 classifier
  272. Jan  1 00:00:19 (none) user.warn kernel:     Performance counters on
  273. Jan  1 00:00:19 (none) user.warn kernel:     input device check on
  274. Jan  1 00:00:19 (none) user.warn kernel:     Actions configured
  275. cpld driver load ok ver:0.0.1
  276. Jan  1 00:00:20 (none) user.warn kernel:
  277. Jan  1 00:00:20 (none) user.warn kernel: cpld driver load ok ver:0.0.1
  278. Jan  1 00:00:20 (none) user.warn kernel:
  279. led: module license 'Itibia GPL' taints kernel.
  280. leds: LED Initialize OK.
  281. Jan  1 00:00:20 (none) user.warn kernel: led: module license 'Itibia GPL' taints
  282. kernel.
  283. Jan  1 00:00:20 (none) user.info kernel: leds: LED Initialize OK.
  284. hwport: hwport module load OK.
  285. Jan  1 00:00:20 (none) user.info kernel: hwport: hwport module load OK.
  286. port 0 now status: 0
  287. send sigal to application,port 0  status: 0
  288. port 1 now status: 0
  289. send sigal to application,port 1  status: 0
  290. port 2 now status: 0
  291. send sigal to application,port 2  status: 0
  292. port 3 now status: 0
  293. send sigal to application,port 3  status: 0
  294. port 4 now status: 0
  295. send sigal to application,port 4  status: 0
  296. port 5 now status: 0
  297. send sigal to application,port 5  status: 0
  298. port 6 now status: 0
  299. send sigal to application,port 6  status: 0
  300. port 7 now status: 0
  301. send sigal to application,port 7  status: 0
  302. Jan  1 00:00:20 (none) user.warn kernel: port 0 now status: 0
  303. Jan  1 00:00:20 (none) user.warn kernel: send sigal to application,port 0  statu
  304. s: 0
  305. Jan  1 00:00:20 (none) user.warn kernel: port 1 now status: 0
  306. Jan  1 00:00:20 (none) user.warn kernel: send sigal to application,port 1  statu
  307. s: 0
  308. Jan  1 00:00:20 (none) user.warn kernel: port 2 now status: 0
  309. Jan  1 00:00:20 (none) user.warn kernel: send sigal to application,port 2  statu
  310. s: 0
  311. Jan  1 00:00:20 (none) user.warn kernel: port 3 now status: 0
  312. Jan  1 00:00:20 (none) user.warn kernel: send sigal to application,port 3  statu
  313. s: 0
  314. Jan  1 00:00:20 (none) user.warn kernel: port 4 now status: 0
  315. Jan  1 00:00:20 (none) user.warn kernel: send sigal to application,port 4  statu
  316. s: 0
  317. Jan  1 00:00:20 (none) user.warn kernel: port 5 now status: 0
  318. Jan  1 00:00:20 (none) user.warn kernel: send sigal to application,port 5  statu
  319. s: 0
  320. Jan  1 00:00:20 (none) user.warn kernel: port 6 now status: 0
  321. Jan  1 00:00:20 (none) user.warn kernel: send sigal to application,port 6  statu
  322. s: 0
  323. Jan  1 00:00:20 (none) user.warn kernel: port 7 now status: 0
  324. Jan  1 00:00:20 (none) user.warn kernel: send sigal to application,port 7  statu
  325. s: 0
  326. yaffs: dev is 32505866 name is "mtdblock10"
  327. yaffs: passed flags ""
  328. yaffs: Attempting MTD mount on 31.10, "mtdblock10"
  329. block 793 is bad
  330. Jan  1 00:00:22 (none) user.info kernel: yaffs: dev is 32505866 name is "mtdbloc
  331. k10"
  332. Jan  1 00:00:22 (none) user.info kernel: yaffs: passed flags ""
  333. Jan  1 00:00:22 (none) user.warn kernel: yaffs: Attempting MTD mount on 31.10, "
  334. mtdblock10"
  335. Jan  1 00:00:22 (none) user.warn kernel: block 793 is bad
  336. yaffs_read_super: isCheckpointed 0
  337. yaffs: dev is 32505867 name is "mtdblock11"
  338. yaffs: passed flags ""
  339. yaffs: Attempting MTD mount on 31.11, "mtdblock11"
  340. yaffs: restored from checkpoint
  341. yaffs_read_super: isCheckpointed 1
  342. Get time...
  343. Probing device eth0:
  344. No such device
  345. Probing device eth1:
  346. PHY found!
  347. PPP generic driver version 2.4.2
  348. PPP MPPE Compression module registered
  349. ip_conntrack_pptp version 3.1 loaded
  350. ip_nat_pptp version 3.0 loaded
  351. usbflash: USB flash driver load.
  352. Register forward hook ok!
  353. regex_init start
  354. regex_init re2post_new end
  355. regex_init:malloc l1(8288),l2(8288)
  356. regex_init OK
  357. dfa_init:smp running in gateway mode
  358. dfa module init ok!
  359. NET: Registered protocol family 24
  360. PPTP driver version 0.8.2
  361. wlan: 0.8.4.2 (Atheros/multi-bss)
  362. ath_hal: 0.9.17.1 (AR5212, RF5111, RF5112, RF2413, RF5413, REGOPS_FUNC)
  363. ath_rate_atheros: Version 2.0.1
  364. Copyright (c) 2001-2004 Atheros Communications, Inc, All Rights Reserved
  365. ath_dfs: Version 2.0.0
  366. Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
  367. ath_pci: 0.9.4.5 (Atheros/multi-bss)
  368. PCI: enabling device 0000:00:0e.0 (0340 -> 0342)
  369. wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
  370. wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36
  371. Mbps 48Mbps 54Mbps
  372. wifi0: mac 7.8 phy 4.5 radio 5.6
  373. wifi0: Use hw queue 1 for WME_AC_BE traffic
  374. wifi0: Use hw queue 0 for WME_AC_BK traffic
  375. wifi0: Use hw queue 2 for WME_AC_VI traffic
  376. wifi0: Use hw queue 3 for WME_AC_VO traffic
  377. wifi0: Use hw queue 8 for CAB traffic
  378. wifi0: Use hw queue 9 for beacons
  379. wifi0: Atheros 5212: mem=0x48000000, irq=26
  380. wlan: mac acl policy registered
  381. usbcore: registered new interface driver usbserial
  382. drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
  383. usbcore: registered new interface driver usbserial_generic
  384. drivers/usb/serial/usb-serial.c: USB Serial Driver core
  385. drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-
  386. port)
  387. usbcore: registered new interface driver zte
  388. drivers/usb/evdo/zte.c: USB Driver for GSM modems: v1.0.1
  389. up: dev_media_check_thread() port=1 PhyIndex=0, linkMonitor=0
  390. eth1.1: Setting MAC address to  00 22 93 e7 bd 9f.
  391. device eth1 entered promiscuous mode
  392. VLAN (eth1.1):  Setting underlying device (eth1) to promiscious mode.
  393. eth1.1: dev_set_promiscuity(master, 1)
  394. device eth1.1 entered promiscuous mode
  395. br-lan1: port 1(eth1.1) entering learning state
  396. br-lan1: topology change detected, propagating
  397. br-lan1: port 1(eth1.1) entering forwarding state
  398. up: dev_media_check_thread() port=2 PhyIndex=1, linkMonitor=0
  399. eth2.8: Setting MAC address to  00 22 93 e7 bd 9e.
  400. device eth2 entered promiscuous mode
  401. VLAN (eth2.8):  Setting underlying device (eth2) to promiscious mode.
  402. qos Interface loaded
  403. Qos_SET_REGS:the qos reg para is:
  404. dev_add: 17, reg_addr:a, val:3000
  405. Qos_SET_REGS:read value you write just now is:
  406. dev_add: 17, reg_addr:a, val:3000
  407. Qos_SET_REGS:the qos reg para is:
  408. dev_add: 16, reg_addr:a, val:3000
  409. Qos_SET_REGS:read value you write just now is:
  410. dev_add: 16, reg_addr:a, val:3000
  411. ixCryptoAccInit failed, assuming already initialised!
  412. klips_info:ipsec_init: KLIPS startup, Openswan KLIPS IPsec stack version: 2.4.9
  413. NET: Registered protocol family 15
  414. klips_info:ipsec_alg_init: KLIPS alg v=0.8.1-0 (EALG_MAX=255, AALG_MAX=251)
  415. klips_info:ipsec_alg_init: calling ipsec_alg_static_init()
  416. ipsec_aes_init(alg_type=15 alg_id=12 name=aes): ret=0
  417. ipsec_3des_init(alg_type=15 alg_id=3 name=3des): ret=0
  418. apam_uduf_set get the uduf switch -- disable
  419. device ra0 entered promiscuous mode
  420. br-lan1: port 2(ra0) entering learning state
  421. br-lan1: topology change detected, propagating
  422. br-lan1: port 2(ra0) entering forwarding state
  423. Itibia Corporation 2008 presents
  424. Bizbox login:
Over,谢谢观赏
关键词: 中国     电信     商务     领航     中兴     定制机     EBG-21
