问题如下:
========== Start build all(2013年9月1日 15:10:47) ==========
------ Start build(sample_LED, DefaultBuild) ------
>r_cg_timer_user.c
r_cg_macrodriver.h(39) : CC78K0R error E0802: Illegal preprocess directive
r_cg_macrodriver.h(40) : CC78K0R error E0802: Illegal preprocess directive
r_cg_macrodriver.h(41) : CC78K0R error E0802: Illegal preprocess directive
r_cg_macrodriver.h(42) : CC78K0R error E0802: Illegal preprocess directive
r_cg_macrodriver.h(43) : CC78K0R error E0802: Illegal preprocess directive
r_cg_macrodriver.h(44) : CC78K0R error E0802: Illegal preprocess directive
r_cg_timer_user.c(39) : CC78K0R error E0301: Syntax error
r_cg_timer_user.c(39) : CC78K0R error E0701: External definition syntax
r_cg_timer_user.c(66) : CC78K0R error E0523: Illegal bit,boolean type operation
r_cg_timer_user.c(66) : CC78K0R error E0711: Undeclared 'P13' ; function 'r_tau0_channel0_interrupt'
------ Build ended(Error:18, Warning:0) ------
========== Ended(Success:0 Projects, Failed:1 Projects)(2013年9月1日 15:10:47) ==========
