请问有用过Cubesuite+的么?我在里面建工程,系统的头文件,怎么包含啊?看他们官方的例程也没有包含头文件,寄存器的地址映射在哪里呢?我编译官网的样板程序也是有错误,错误提示如下:
RA78K0 error F3006: File not found 'DefaultBuild\block.rel'
RA78K0 error F3006: File not found 'DefaultBuild\drive.rel'
..\sourcefile\block.c(44) : CC78K0 warning W0837: Output assembler source file , not object file.\sourcefile\block.c(44) : CC78K0 warning W0837: Output assembler source file , not object file
..\sourcefile\block.c(35) : CC78K0 warning W0410: Illegal pointer conversion
..\sourcefile\block.c(88) : CC78K0 warning W0401: Conversion may lose significant digits
..\sourcefile\block.c(104) : CC78K0 warning W0401: Conversion may lose significant digits
..\sourcefile\block.c(147) : CC78K0 warning W0401: Conversion may lose significant digits
..\sourcefile\block.c(148) : CC78K0 warning W0410: Illegal pointer conversion
..\sourcefile\block.c(31) : CC78K0 warning W0915: Asm statement found. skip to jump optimize this function 'write_dat_to_flash'
..\sourcefile\block.c(117) : CC78K0 warning W0915: Asm statement found. skip to jump optimize this function 'set_block_valid'
..\sourcefile\block.c(143) : CC78K0 warning W0915: Asm statement found. skip to jump optimize this function 'creat_write_block'
..\sourcefile\block.c(173) : CC78K0 warning W0915: Asm statement found. skip to jump optimize this function 'set_block_mode'
>..\sourcefile\drive.c
..\sourcefile\drive.c(240) : CC78K0 warning W0837: Output assembler source file , not object file
..\sourcefile\drive.c(237) : CC78K0 warning W0915: Asm statement found. skip to jump optimize this function 'send_if_dat'
..\sourcefile\drive.c(566) : CC78K0 warning W0915: Asm statement found. skip to jump optimize this function 'Open_2ms'
..\sourcefile\drive.c(587) : CC78K0 warning W0915: Asm statement found. skip to jump optimize this function 'Close_2ms'
>DefaultBuild\testv_01.lmf
这是一大堆的警告,项目刚用这个单片机,开发环境不熟悉,请大虾们多多援手啊。。。
共9条
瑞萨单片机开发工具Cubesuite+的库文件找不到?
你安装的时候,没问题吧?会不会安装的时候,某些部分被360阻击了什么的~
官方程序直接运行都有问题的话,开始怀疑的cubesuite+本身的问题了...重装一下试试....
请问这个头文件在哪里可以找到?Cubesuite都支持哪些头文件?不同的CPU包含的头文件一样么?有没有这方面的文档介绍,我在官网上没找到,我看哪些文档都是粗略的介绍,没有细致的描述啊?
还有像这样的错误怎么找啊?
这本是官网一个电表的方案的源码,我建工程,添加进去,直接编译就出错,是编译环境没设置好,还是什么原因?
问题好多,先说声谢谢。。
库文件的问题解决了,打电话问的厂家,日本做的芯片真狠,直接封装的连地址映射都看不到,只需要#pragma SFR就可以直接操作寄存器,屏蔽底层比美国货更绝,服了。。。
第二个问题,还是没解决,望高手指点,这类错误怎么解决?
共9条
| 有奖活动 | |
| 2026年“我要开发板活动”第三季,开始了! | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| 打赏了!打赏了!打赏了! | |
| 空气质量检测器设计与实现被打赏¥24元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】LWIP进行UDP、TCP、HTTP、MQTT功能联合测试被打赏¥41元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】RA8D1部署FreeRTOS+LWIP被打赏¥36元 | |
| RTOS怎么选?让我来给你答案!被打赏¥15元 | |
| 【S32K3XX】Flash驱动使用被打赏¥26元 | |
| 【FreeRtos】第一个任务的启动过程被打赏¥21元 | |
| 【分享开发笔记,赚取电动螺丝刀】FPB-RA6E2开发板的WDT功能测试被打赏¥22元 | |
| 关于cmakelist特性presets的使用被打赏¥20元 | |
| 【分享开发笔记,赚取电动螺丝刀】M5STACK系列屏幕质量测试程序,竟然有块亮斑?被打赏¥20元 | |
| 【分享开发笔记,赚取电动螺丝刀】快速搭建瑞萨FPB-RA6E2开发板开发环境被打赏¥14元 | |
