电子产品世界 » 论坛首页 » 高校专区 » 坤创E-Geek/天科大新电社 » 时钟电路程序
共15条 1/2 1 2 › 跳转至页
时钟电路程序
2013-11-20 22:10:19     打赏
void delay(int z)
 int x,y;
 for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write_com(char com)   //写指令操作
rs=0;
lcden=0;                                   //这一步万万不可少,否则不出结果
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void didi()
 beep=0;
 delay(50);
 beep=1;
 delay(100);
 beep=0;
 delay(50);
 beep=1;
void write_data(char date)      //写命令操作
rs=1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;                                 //使用完毕后一定要释放使能端  即置零
void init()                      //初始化函数
char num;
EA=1;
EX0=1;
IT0=1;
wela=0;
dula=0;
lcden=0;
set_alarm(17,13,30);
write_ds(0x0B,0x26);
read_ds(0x0c);
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<15;num++)
write_data(table1[num]);
delay(5);
write_com(0x80+0x40);
for(num=0;num<10;num++)
write_data(table2[num]);
delay(5);
void write_time(char clock,char address1)
char ge,shi;
shi=clock/10;
ge=clock%10;
write_com(0x80+0x40+address1);
write_data(0x30+shi);
delay(10);
write_data(0x30+ge);                                 //记住此处一定要加0x30     因为char型数字+0x30才能在液晶上显示出来,另外字符如a,b等可直接显示
}                                                   //例如write_data(a)    write_data(5+0x30)才是对的//不能写write_data('a')或write_data(5)
void keyscan1()                     //加法检测
if(s17==0)
delay(50);
if(s17==0&flag1==1)
flag1=0;
if((s17==0)&&(s13num==1))
if(miao==59)
miao=0;
miao++;
write_time(miao,0x08);
if((s17==0)&&(s13num==2))
if(fen==59)
fen=0;
fen++;
write_time(fen,0x05);
if((s17==0)&&(s13num==3))
if(shi==23)
shi=0;
shi++;
write_time(shi,0x02);
while(!s17);
void keyscan2()               //减法检测
if(s21==0)
delay(50);
if(s21==0&flag1==1)
flag1=0;
if((s21==0)&&(s13num==1))
if(miao==0)
miao=59;
miao--;
if((s21==0)&&(s13num==2))
if(fen==0)
fen=59;
fen--;
if((s21==0)&&(s13num==3))
if(shi==0)
shi=23;
shi--;
while(!s21);
void keyscan()               //复位键检测
rd=0;
if(s13==0)
delay(5);
if(s13==0)
flag=1;
TR0=0;
s13num++;
while(!s13);
if(flag1==1)
s13num=4;
flag1=0;
write_com(0x0f);
if(s13num==1)
write_com(0x80+0x40+0x08);
if(s13num==2)
write_com(0x80+0x40+0x05);
if(s13num==3)
write_com(0x80+0x40+0x02);
if(s13num==4)
s13num=0;
flag=0;
write_com(0x0c);
write_ds(4,shi);
write_ds(2,fen);
write_ds(0,miao);
keyscan1();
keyscan2();
void write_ds(char add,char date)
dscs=0;
dsas=1;
dsds=1;
dsrw=1;
P0=add;
dsas=0;
dsrw=0;
P0=date;
dsrw=1;
dsas=1;
dscs=1;
char read_ds(char add)
char ds_date;
dscs=0;
dsas=1;
dsds=1;
dsrw=1;
P0=add;
dsas=0;
dsds=0;
P0=0xff;                          //此处一定要给P0附0xff
ds_date=P0;
dsds=1;
dsas=1;
dscs=1;
return ds_date;
void set_time()
write_ds(4,15);
write_ds(2,03);
write_ds(0,50);
void set_alarm(char ashi,char afen,char amiao)
write_ds(1,amiao);
write_ds(3,afen);
write_ds(5,ashi);
void main()
init();
while(1)
keyscan();
if(flag1==1)
didi();
if(flag==0)
miao=read_ds(0);
fen=read_ds(2);
shi=read_ds(4);
void ext0() interrupt 0
char c;
beep=0;
c=read_ds(0x0C);
flag1=1;
2013-11-20 22:13:11     打赏
这是。。。额,好吧,支持一下
2013-11-20 22:14:15     打赏
程序老长了   注释没几行~
2013-11-20 22:15:01     打赏
哈哈哈哈 。。。呵呵
2013-11-20 22:15:26     打赏
大神教训的是,可读性太差
2013-11-20 22:22:18     打赏
没看懂是什么的时钟,楼主来个简介呗
2013-11-20 22:31:47     打赏
老油条们都在等着LZ赐教呢
2013-11-20 22:35:25     打赏
嘿嘿
我猜是按键,蜂鸣器,1602液晶显示,按键扫描。
2013-11-20 23:14:39     打赏
表示还是喜欢写成库函数来用
2013-11-21 08:54:46     打赏
哇~~
好长的程序啊~~
共15条 1/2 1 2 › 跳转至页
