电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » CPLD的一个奇怪问题
共4条 1/1 1 跳转至页
CPLD的一个奇怪问题
2013-11-25 10:04:13     打赏
用CPLD做编码器的解码,用的是状态机写的485通讯,遇到一个很奇怪的问题,写的状态机如下:
       case(state)
        Idle:
         begin
            over <= 1'b0;
            txd <= 1'b1;
            if(start_fg == 1'b1)
            begin
               state <= Request;
               E_c <= 1'b1;
               start_fg1 <= 1'b1;
            end
         end
        Request:
         begin
            if(i == 8'd10)
              begin
                 state <= Wait;
                 start_fg1 <= 1'b0;
                 E_c <= 1'b0;
                 CF_r <= 10'd0;
                 txd <= 1'b1;
                 i <= 6'd0;
              end
           else
             begin
                txd <= CF[6'd9-i];
                i <= i+1'b1;
             end
         end
       Wait:
         begin
             txd <= 1'b1;
             E_b <= 1'b1;
             if(CF_r[3:0] == 4'b0010)
               begin
                    state <= Receive;
                    i <= 6'd0;
                    CF_r <= (CF_r << 1)|re;
                    i <= 6'd4;
               end
             else
               begin
                     if(i == 4'd14)
                       begin
                         state <= Idle;
                         erro <= 2'd3;
                       end
                     else
                       begin
                          i <= i+1'b1;
                       end
                end
         end
         Receive:
            begin
              if(i < 6'd9)
                begin
                   i <= i+1'b1;
                 end
               else if(i == 6'd9)
                  begin
                    if(CF_r == CF)
                        begin
                          CRC_buf <= CRC_buf|{CF_r[8:1],40'd0};
                           i <= i+1'b1;
                        end
                    else
                       begin
                          state <= Idle;
                          i <= 0;
                         erro <= 2'd0;
                       end
                   end
                else if(i < 6'd19)
                   begin
                      i <= i+1'b1;
                   end
                else if(i == 6'd19)
                   begin
                      if(CF_r[4] | CF_r[3])
                        begin
                           erro <= 2'd2;
                            i <= i+1'b1;
                         end
                      else
                        begin
                            CRC_buf <= CRC_buf|{CF_r[8:1],32'd0};
                            DATA_TEMP <= (DATA_TEMP >> 1)|{re, 29'd0};
                            i <= i+1'b1;
                        end
                   end
                 else if(i < 6'd49)
                    begin
                       i <= i+1'b1;
                    end
                 else if(i < 6'd59)
                    begin
                       i <= i+1'b1;
                    end
                 else
                    begin
                       DATA_TEMP[23:0] = {DATA_TEMP[28:21],DATA_TEMP[18:11],DATA_TEMP[8:1]};
                       for(i = 6'd0; i < 24; i = i+1'd1)
                       begin
                          CRC_buf[31-i] = DATA_TEMP;
end
                      CRC_buf = CRC_buf|CF_r[8:1];
                     for(i = 6'd47; i > 6'd7; i = i-1'b1)
                     begin
                       CRC_buf[47:40] = {CRC_buf[46:40],(CRC_buf[47]^CRC_buf[39])};
                       CRC_buf[39:0] = CRC_buf[38:0]<<1; //shift
                     end
                     if (!CRC_buf[47:40])
                       begin
                          DATA_LAST =DATA;   //24'd3;//
                          DATA =DATA_TEMP[23:0];  //24'h01fffd; //
                       end
                    else
                     begin
                          CRC_buf[47:40]=8'd0;
                         DATA=24'hffffff;
                     end
               state <= Idle;
               E_b <= 1'd0;
               i <= 6'd0;
               over <= 1'd1;
            end
         end
       endcase
加了一句如下划线的语句后,状态机不跳了,txd没有输出,看RTL Viewer太复杂了查不过来,有没有哪位有经验的前辈能够指点一下这会是什么原因呢?DATA跟状态机完全没有关系呢。。
关键词: CPLD 问题
2013-11-25 10:42:42     打赏
逻辑很混乱啊,阻塞赋值和非阻塞赋值都有啊,另外你看下你的状态机跳转和你的设计方案是否一致。
2013-11-25 10:45:45     打赏
您好,阻塞的是因为在for里面才用的,状态机的跳转和设计方案是一致的,modelsim仿真没有问题,quartus编译下载到板子里也可以正常通讯就是有时候改一些这种觉得没关系的地方会影响通讯,所以想请教是什么原因导致?
2013-11-25 10:54:34     打赏
功能仿真没问题的话,可能就是时序的问题了,你看看quartus编译时有没有时序告警。
共4条 1/1 1 跳转至页
