共10条
TFFS 2.0(?)不支持DOS长文件名!
我用的tornado2.02自带的tffs文件系统不支持dos长文件名!这太让人沮丧了!!昨天我用usrTffsLnConfig()来实现tffs,当我创建了几个长的目录名关机重启后,发现这几个根本就找不到啦!
后来我在google的vxworks新闻组上找到了原因:tffs对dos文件系统的结构非常敏感,要安全地使用它就只能用它自带的程序格式化,而不能用dosFsMkfs()来完成。但长文件名本身就是非标准的,它只能用dosFsMkfs()来创建,如果在tffs上实现长文件名,则造成的后果就是文件数据的丢失!
这就是原因的所在。
全方如下,唉,人家早在1999年就已经在讨论这个问题了,想不到我们落后了这么久。。。
新闻群组
Groups search result 5 for long name group:comp.os.vxworks
Search Result 5
寄件者:Leonid Rosenboim (leonid@bitband.com)
主旨:Re: Long File Name support TFFS
View: Complete Thread (2 articles)
Original Format
新闻群组:comp.os.vxworks
日期:1999/09/05
Assuming you are using the old dosFs, which is shipped with Tornado 2, then
you are out of luck:
TrueFFS is very nosy about the DosFs structure stored on its volumes, and
the only safe way to use it is to format a TrueFFS volume only with the
format function supplied with TrueFFS. Never use dosFsMkfs() to format a
TrueFFS volume.
DosFs long names are non-standard, and can be created only with dosFsMkfs(),
and are known to cause file data to dissapear when used with TrueFFS,
because TrueFFS's idea of the meaning of some fields in the boot block and
DosFs's idea vary. This has been documented in the SPR database.
Your solution is to either go to DosFs 2 which supports standard VFAT long
names, or to do away with TrueFFS.
Frankly I do not see why anyone would still bother with TrueFFS at all, you
can get lower price per Megabyte with ATA-based Compact Flash cards, and not
worry about any software issues, and remain vedor independent, buy the CF
cards where it is cheaper.
HTH,
Leonid
Anurag Srivastava wrote:
> > Hi everybody,
> > I need long file name support on TrueFFS. I am making DOS file system
> > with long file name support and it is working . Does this support is
> > provided in tffs for Tornado. If yes , then please send me the command
> > to do s.
> > Thanks,
> > Anurag.
©2002 Google
关键词: 不支持 文件名
[quote][b]以下是引用[i]vxfree在2002-10-17 11:08:03[/i]的发言:[/b]
dosFs甚至不能认识多分区和FAT32!dosFs2.0可以。
如果购买了正版Tornado,应该向代理商申请免费升级。
我有dosFs2.0,可惜30多M,我拨号上网...
[/quote]
5555555555~~~~~~`!
最可气的是老板找他一个朋友搞到的tornado2.0开发包!说以后产品量产了就去买正版(谁知道会不会呀,毕竟要那么多MONEY),现在什么支持也没有,幸亏坛子里兄弟们的帮助,不然我可惨了:)真是太羡慕vxfree兄了,有那么多好东东可以把玩,兄弟我就只有瞧着流口水的份儿了。。。。。(要是你有adsl就好乐。。。。)[em20][em20][em01][em01][em01][em01]
从出错信息可以看出,你在sysSerialHwInit()中调用了i28f160Identify导致出错!我是在s3c4510b上实现MTD驱动的,我对860不熟悉,不知道为何在sysSerialHwInit()中要调用??
解决的方法:1.还是在sysSerialHwInit()之前先声明一下i28f160Identify().
2.你先看一下你的编译过程,显示的信息中是否有编译你的MTD驱动i28f160.o的信息?如果没有,这就是原因所在了!直接把i28f160.c放到你bsp所在目录,并修改makefile加入i28f160.o的编译,应该就OK了.
共10条
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 | |
汽车电子中巡航控制系统的使用被打赏10分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏100分 | |
分享汽车电子中巡航控制系统知识被打赏10分 | |
分享安全气囊系统的检修注意事项被打赏10分 | |
分享电子控制安全气囊计算机知识点被打赏10分 | |
【分享开发笔记,赚取电动螺丝刀】【OZONE】使用方法总结被打赏20分 |
